Headlight Bulb Issue
So i decided to replaced my low beams with some 6000k bulbs. I bought 2 pairs from different sellers. The first pair worked initially but the passenger side would then flicker and shut off. Sometimes it would come on if i turned them on and off sometime it wouldnt. I swapped the bulbs to other side but the problem stayed on the passenger side. Then i installed the 2nd pair i bought. There was no flickering but the passenger side would shut off after some time.
At this point i figured my ballast is gone. I installed my factory bulbs and everything works fine???
Anyone have this type of an issue? Do i have to get Philips 6000k bulbs? for it to work properly?
btw, the first pair were from DDM Tuning which ive never had an issue with in the past and the 2nd pair from ebay.
Any help would be appreciated, thanks
yea it looks like thats what i am going to have to ..it was just weird that even when i switched the bulbs only my passenger kept going out until my stocks were put back on....i have hid fogs also which work perfect but i dont think that has anything to do with it
True Phillips cost $200+ Even on ebay. Personally I would never pay that much for bulbs unless I was super ballet I guess. I got the Xenondepot bulbs now and they work great. A lot of ppl have had success with Garax as well.
DDM Tuning is a worst bulbs you can buy. eBay isn't any better. Buy from a company with a good reputation. Those bulbs probably ruined your ballast.
+1 for the Retrofitsource
I'm running 5000k bulbs from the retrofit source:
http://www.theretrofitsource.com/pro...oducts_id=3180
Teachustea
11-25-16 06:18 PM
