Strange noise when accelerating at WOT
Old 02-24-13, 09:58 PM
ISF4life
ISF4life's Avatar
No problem sir, glad i can help
Old 02-24-13, 11:42 PM
ISFPOWER
ISFPOWER's Avatar
i agree with blitz. i had the same sound. usually in first gear in manual mode, if i stomp on the gas, it would sound like a supercharger belt whine until second gear. it was just the belt, it went away after changing it.
Old 02-24-13, 11:55 PM
BULLIT
BULLIT's Avatar
I dont drive my car hard and only notice it occasionally. This seems like a common problem and am surprised no one has mentioned it before. Have to get dealer to check it next service.
How often is timing belt supposed to be changed 100k? My car has only done 20,000km
Old 02-24-13, 11:56 PM
ISFPOWER
ISFPOWER's Avatar
im pretty sure this car uses a timing chain like most v-series cars nowadays. i dont think its a maintenance item.
Old 02-25-13, 12:06 AM
ISF4life
ISF4life's Avatar
Its a drive belt is not timing belt=timing chain in the F.
Old 02-25-13, 12:07 AM
BULLIT
BULLIT's Avatar
Sorry meant drive belt. Your a wealth of information blitz:-)
Old 02-25-13, 12:10 AM
ISF4life
ISF4life's Avatar
eheeheh just want to help fellow members we have very high standard in ISF CL unlike other forums
Desecate (04-26-22)
Old 02-25-13, 07:35 AM
Joe Z
Joe Z's Avatar
Received 1,058 Likes on 586 Posts
Lightbulb FYI for All...
This "swooooosh" sound is mostly heard between WOT shifting from 1 - 2 - 3 gears...
I had the noise for a while.. First I thought tires... then maybe trans...
After I ruled out the trans, and tires (ran OEM Bridgestones, PS2's & Conti's)
I came to the belt conclusion..
The drive belt doesn't need to look old or cracked for it to make noise.. I attribute it to loss of grip, which causes the sound..
Some of you with low miles, might be experiencing the sound due to age...
My case was age + miles.. But it still looked very good!! ( a bit shiny )
The harder you run your car, the more likely the sound will show up sooner..
Here is a pic of when I changed mine in the below thread.
https://www.clublexus.com/forums/is-...-belt-diy.html
~ Regards,
Joe Z
Old 02-25-13, 08:11 AM
KOKISF
KOKISF's Avatar
rule out timming belt if that one slips the motor will get destroyed!!!
Old 02-25-13, 09:32 AM
Joe Z
Joe Z's Avatar
Lightbulb
What timing belt..???
The 2UR-GSE motor runs two chains..
~ Joe Z
Old 02-25-13, 09:56 AM
Murph145
Murph145's Avatar
i like my car when it makes the squealing noise lol!
good info ill hit up a local dealer one of these days to have them replace it
Old 02-25-13, 05:51 PM
stvincent
stvincent's Avatar
i have the same noise, like supercharger whining at wot. since i recently replaced the drive belt from dealership, and it's still making this noise.. should i be concerned?
Old 02-26-13, 10:32 AM
Joe Z
Joe Z's Avatar
Arrow
"Dealership" work should be under warranty... Have them see if the tensioner pulley & water pump pulley are working correctly..
If it’s still making noise, it could very well be the “Tensioner Pulley” that has failed..
As shown here: Drive Belt DIY
~ Joe Z
Old 02-26-13, 02:37 PM
PhiDeltBee
PhiDeltBee's Avatar
Always count on Joe! It's like you have all the thread answers on tap.
Old 08-14-13, 08:57 PM
cremaster
cremaster's Avatar
can someone tell me if the "slipping" belt affects the performance in any way? loss in power? any other negatives?
also, anyone that had this fixed, was it covered under warranty? thanks!
Quick Reply: Strange noise when accelerating at WOT
