which limited slip differential is the best!
Hi
I just want to know which limited slip differential (LSD) is the best for my ISF 2009 between:
1) OS GIKEN
2) CUSCO
3) TOMS
4) or the OEM 2011 ISF LSD
I want my car run more
Thanks
Eddie Feng
1) OS GIKEN
2) CUSCO
3) TOMS
Thanks
Eddie Feng
most likely the OSgiken Elsd. If you want the best results stock is probably the best since it will be quite and reliable. Aftermarket LSD;s tend to be for more of the hooligan types IMO that like to drive with chatter here and there depending on how agressive or what type you buy.
Best bang for the buck is the 10+ up LSD unit which you can try to find used.
https://www.clublexus.com/forums/is-...eted-pics.html
Best "racing" diff is the OS Gikken which one needs to setup in the car and works differently than the 10+ diffs.
Tech Info Resource
Best is a very relative term.
I use my car everyday as my regular car but somedays i like to drag with my friends in the streets and in the drag stadium. I just want it to have the best respond and top speed
