IS-F Centre Dash Speaker
Old 10-30-15, 05:26 AM
  #31
myspec15
myspec15's Avatar
what's the size of the center speaker thanks
Old 10-30-15, 08:45 AM
  #32
MannyRCF
MannyRCF's Avatar
Lol I have the same issue...I was under the impression I had to disassemble the whole dash...I'll try this fix this weekend.
Old 10-30-15, 09:35 AM
  #33
Twotwo
Twotwo's Avatar
Default Speaker
Good job glad we got it fixed.........
Old 09-26-16, 09:11 AM
  #34
topguy573
topguy573's Avatar
anyone ever come up with a replacement size? or is it best to just get the speaker repaired? Ive had issues with my center speaker for awhile, and just blew the driver side tweeter this past weekend.
Old 11-06-16, 04:43 AM
  #35
s6 4rings
s6 4rings's Avatar
My ML center channel speaker is shot too, how do i pull cover off? i dont want to mark up the dash.where exactly do i put a credit card?
Old 11-07-16, 11:53 AM
  #36
Joker4096
Joker4096's Avatar
Under the edge of the cover where it meets the dash. then pry up.
Old 07-19-17, 07:27 AM
  #37
PandaJR
PandaJR's Avatar
I just want to say thank you to everyone on this post. I recently purchased an ISF that had this exact issue. Easiest car repair I have ever had to make.
Old 06-27-19, 02:18 AM
  #38
Clydespop
Clydespop's Avatar
Default Same thing with my GS 350
You can't teach an old dog new tricks, but an old thread can get the rattle snake out of your dash. A razor blade and super glue, done. Worked perfectly. Thanks.
Old 06-27-19, 07:46 AM
  #39
WeekendF
WeekendF's Avatar
Gotta love these old threads that come back to life.. Both my front and rear center speakers were rattling... Fixed thanks to this!
Old 07-20-20, 07:28 AM
  #40
TripleD
TripleD's Avatar
Do the rear speakers by the rear window remove the same way, can you just pop the covers off and remove, or do you remove these from inside the trunk area?
Old 07-20-20, 09:21 AM
  #41
Rickna
Rickna's Avatar
You will need to remove the back seats, rear deck and the side panels.
Old 08-15-20, 11:42 AM
  #42
Crrober3
Crrober3's Avatar
Originally Posted by Reyes1
Ok, so I removed the Speaker held by two 10mm Bolts. Peeled half of the fabric that covers the speaker and sure enough, what appears to be a Dust Cap, had come loose and was causing the noise. Glued it back in place, put the Speaker back in and the problem was solved, no more noise!
But what are the steps to remove the panel to get to the speakers?
Old 08-15-20, 12:13 PM
  #43
Joker4096
Joker4096's Avatar
Just pop off the speaker grille on the dash and the speaker will be visible.
Old 10-04-20, 06:30 PM
  #44
ELexis
ELexis's Avatar
Originally Posted by Twotwo
Easy fix o just had to glue it back
Just glue it.. So easy
Easy to take off just use a credit card and then take off 2 10mm bolts
I understand this to be an older post however, believe to be experiencing the same issue (buzzing noise. like something is loose from Mark Levinson center dash speaker). Would like to confirm if the following procedure would be correct fo non IS F vehicle (IS350), as well. Appears speaker had already been removed prior to beginning video tutorial, and would like to confirm if there is a recommended location to begin removing speaker grill cover from dash;
Old 10-04-20, 06:36 PM
  #45
Joker4096
Joker4096's Avatar
Originally Posted by ELexis
I understand this to be an older post however, believe to be experiencing the same issue (buzzing noise. like something is loose from Mark Levinson center dash speaker). Would like to confirm if the following procedure would be correct fo non IS F vehicle (IS350), as well;
https://youtu.be/ylKtWUUEF_E
It's the same dash so the procedure is the same. Just lift it up from anywhere on the edge of the speaker grille.
Quick Reply: IS-F Centre Dash Speaker
