Question from a new ISF owner
Old 11-26-12, 08:24 PM
LexusISF23
LexusISF23's Avatar
Default Jump 200-300 RPM's when coming to a stop in Auto?
Hello everybody, this is my first post but i have read these forums a lot and they have been quite helpful in my purchase of a new 2012 ISF. I have had the car for about a month now, and as expected, its a blast! I do have an issue that i was hoping to get a response from fellow ISF owners. I have test driven '10 and '11 ISF's, so i knew what to expect as far and how the car drives, but something on this new 2012 ISF is bothering me. Maybe I'm not remembering correctly, but the other 2 ISF's that I've test driven seemed to be incredibly smooth while coming to rolling stop. But that isn't the case with my new 2012.
When coming to a rolling stop, my RPM's will jump about 200-300 pretty much everytime, and if your not fully planted in your seat you body will be pushed slightly forward when this happens, which is quite annoying and unexpected for a $65,000 Lexus. The same thing happens but even worse when the car is in Manual mode, as the jump in RPM's (as well as the foward body sway) is even more exaggerated. I switched the display to show when the gears are shifting, and this happens when the car is slowing to a stop and it switches down from 3rd to 1st. In fact I've been watching this for a while and the car never goes from 3rd to 2nd to 1st, instead always skipping 2nd. It's at this moment the car jumps 200-300 RPM's so i know it's related, but my question is if this is normal. I've been searching the forums and cannot find any threads on this, so either i am one of a few with this problem, or this happens to every ISF and it is no issue. I wish i could go back and test drive the ISF's i did before but they are sold now, so i have nothing to compare it too besides my memories. Could anyone help out please in commenting whether or not this is an issue?
Old 11-26-12, 08:27 PM
LexusISF23
LexusISF23's Avatar
I also wanted to note this isn't after excessive speeding or anything, just from driving at normal speed and coming to a stoplight.
Old 11-27-12, 09:43 AM
VtotheJ
VtotheJ's Avatar
My 08 F does this in M mode as well. When I see the gear shifts, it does go from 3 to 1 occasionally. I doubt this is an issue.
Old 11-27-12, 09:47 AM
Lexura1414
Lexura1414's Avatar
In manual mode, I have this. Are you experiencing this in auto mode as well?
Old 11-27-12, 09:58 AM
cremaster
cremaster's Avatar
never experienced that in auto mode. there is a slight downshift "jerk", if you will, but nothing like what you're describing. of course in manual mode it's more pronounced, esp when you're the one downshifting.
Old 11-27-12, 11:31 AM
nonford
nonford's Avatar
The only suggestion I can offer is to reset the ecu and see if this helps adapt your transmission. Pulling the EFI and ETCS fuse will perform the reset and not mess with your seat , radio or other settings. If no improvement is seen, take her in....
Old 11-27-12, 12:14 PM
SeanGTS
SeanGTS's Avatar
Only in manual mode on the 2 1 shift depending on the rpms (higher seems better). Never in auto
Old 11-27-12, 01:37 PM
LexusISF23
LexusISF23's Avatar
Yes it does it in Auto, it is just much more pronounced in M mode.
Old 11-27-12, 01:41 PM
LexusISF23
LexusISF23's Avatar
When you guys are in Auto mode, do you notice a jump in about 200-300 RPM's when this downshift occurs, when you are slowing to a stop that is? It usually jumps from about 700-800 RPM's to about 1,000 when this Auto shift happens from 3rd to 1st.
Old 11-27-12, 01:43 PM
Lexura1414
Lexura1414's Avatar
Have it checked by the dealer. What you are experiencing is not common among ISF owners. I believe you are the first one to have this symptom. But I might be wrong. Good luck!
Old 11-27-12, 02:17 PM
Wakemaker8
Wakemaker8's Avatar
Can't recall this being a problem but I will try and see if I can replicate what you mean on the drive home. I do know that both my F and my Mom's IS350 jerk rather hard when in manual mode and shifting to first gear.
Old 11-27-12, 04:18 PM
DCoolBeans
DCoolBeans's Avatar
I'd do this first. If this keeps on happening def take it to the dealer.
This does not happen in my car in Auto mode
Old 11-27-12, 06:47 PM
CCLSVTF
CCLSVTF's Avatar
Like everyone else, I get this in Manuel but not in Auto..... Sorry I cant help....
Old 11-28-12, 07:30 PM
anxiouz
anxiouz's Avatar
I only drive in Manual but coming to a stop when the car shifts on it's own into 1st it's lurchy (I have an 08). I have actually developed a technique to slow the car to a stop and time the lurch while braking so that it's not really noticeable. I guess I have just adapted to it because it's second nature now.
But yes, downshifting into 1st for me is lurchy/lumpy/not as smooth as in other cars I've driven.
geero
RC F (2015-present)
24
01-20-16 02:31 PM
3nergiz3d
IS F (2008-2014)
22
10-01-15 11:16 AM
primitive1
06-05-13 08:08 PM
PhilipMSPT
CL of Southern California
207
11-09-08 08:55 PM
y2ks2k
IS F (2008-2014)
03-16-08 04:40 PM
Quick Reply: Question from a new ISF owner
