BC Coilovers..best spring rates for comfort?
#92
I have not tinkered with any of the arms or additional suspension components, and mine feels quite smooth and planted. Gaining feedback from my passengers and their positive impressions of how the car behaves on both smooth and jagged roads here in LA is more of the norm now. I am at 16k/12k with upgraded Swift springs with both front and rear settings to hardest/stiffest. It is also note mentioning that I am not dumped by any means, as my shop and I determined a subtle 2/3 in. drop all around would suffice and allow the car to have my wheels and tires fitted without issue.
#93
Here is my 08 on BC racing with swift 14/10. I have it set at 20/25 from full stiff and it rides pretty well! Harsh bumps are no where near as bad, but it is a bit soft in that it's a little floaty. Just fine for me as it's a 3k a month daily. Can always tighten up for any sporty driving days, takes all of 1 minute for both sides. I am pretty content, as the 08 suspension was really making me reevaluate my purchase. Owned plenty of sports cars before that were nowhere near as harsh.
Now then, nearly two years is the longest I've owned the car and between loving it and about to be married, my preferred choice is to simply upgrade/update the car and keep it another 1-2 years. I am looking to upgrade to either 16/12 or 16/10 new BC racing+swift coils, or better yet the HKS Hipermax around the $2k range, or perhaps the greddy/kw for $1300-1400 range. RR Racing and Fortune auto are also in the running, though people seem to have less experience with them. Greddy/kw seem soft at 15/10, but a nice price for a better name/quality. HKS seem like it's where it's at for the price range, but I've gone nearly two years on BC, and can't say I've been unhappy, just maybe went too soft with the 14/10 rates..Yes, the handling lost some of it's track focused setup, but I've only autoxed and dragged once and taken many many more 5+hour trips. So kind of lost on if the better coils are worth the price if I've been "happy" thus far. Have considered just swapping front springs and have been told that coils should last me another 50k easy..but who wants that risk? end of rant. Any thoughts on what I should do?
Pic for attention of current setup:
#94
I went with BC 16/10 set up and have no complaints, The summer time ride is great, maybe it just me but it seems to take a little bit longer in the winter for them to warm up, you can feel the stiffness in the cold weather. Yes I daily drive this in all year round in Canadian weather and I love it!
LexusfanVA (08-06-18)
#95
BR 21 series.
Daily driver, 42k on them so far, only the front right strut mount bushing has worn out.
12k/10k bc springs, front struts set 4-6 off hardest, rear set 6 off hardest because we have alot of potholes here in Philly, but when hitting big road bumps at speed it hits Hard!
#96
Guys the springs are your gross travel limit and our suggestions are based on how you will use the car.
14/10 is a setup for stock power, wheels, tires looking for the ability to adjust for more spirited driving and better balance but not the added energy of modifications, lowering beyond that 1" front and .6" rear and with comfort in mind. The 16/12 is just a step up of 120lbs/in on each corner of travel limit. That means for people looking for a lower ride, or aggressive fitment, or added power/braking, they will resist this added energy. The damping is the "how fast will the suspension travel" portion of the equation and where most of the perceived comfort comes in. We derived these rates from street and track testing on different tires and ride heights. Currently with the advancements to our car we are running 18k/14k on the Penske shocks that utilize a more sophisticated vavle design (dual flow) that can handle the complex energy exchange in the fluid. The 18k/14k rates will be too narrow a dynamic range with the BC damper design as it will push you into the more restrictive rebound settings which will cause the ride to go unbounded (bouncy).
The 16/12 setup is intended to add more dynamic range to the damping adjustment for spirited drivers and get more settings our of the shock that are usable. The balance has been chosen due to the braking power and the F's tendency to shift a lot of weight fwd. The rear-link design bumpsteers and with our suspension we actually like to have the rear settle the remainder of the front's shockwave by both steering into the corner appropriately and damping in a difference mode that the front. For this reason we also always have you tune the front damping first, then let the rear come in after to get the remaining settling done.
Its a pretty simple equation for a very simple shock design in the BC. To get more complicated, you need a more sophisticated means of tuning the damping. This is one reason we worked on the Ohlins setup as a stepping stone to the full Penske setup. It has a more sophisticated valve design that will handle higher rates batter if chosen. So far I think most people would feel pretty uncomfortable pulling the G's we are doing now with relative ease, but its a different level of product.
So look at your preferences, look at your long term goals for the car and give us a call, test or email and we will do our best to set you up for how you would prefer a car to handle.
Thanks
Mike
Thanks
Mike
Very old thread. but how would this coilover setup (18k/14k) withstand with the newer DS shocks by BC racing? Would any major bouncing occur?
#97
I find that the BC struts last about 70-75k (But deterioration starts at 25-30k)
and the strut mounts (if rubber) last about 20-30k (Front) and 40-50k (Rear) depending on road conditions.
#98
The Maker
Unless you are on full r-compound tires I think that 18/14 spring rate would be unnecessary unless you were excessively low. The DS is going to have a stiffer damping curve in the low-speed range, meaning it will sway less on the initial steer in. Bouncing tends to fall into the high-speed range and the DS will be roughly the same in that range. So it all depends on how you intend to use the car ultimately and your ride height.
Mike
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
#99
The Maker
Assuming be the application that you have these on a GS450?
Mike
__________________
#100
Currently I run HKS hipermax 4 with their 16/10 rates. Absorb bumps better and handle nicely in the corners but still a bit too soft if you want to go lower than an inch. Keep in mind my wheel specs are also more aggressive than stock and fairly flush. I only rub every so often really, just on the worst dips or bumps.
samsonn25 (07-02-19)
#101
Bouncing is really a function of damping adjustment. The spring rate will deliver appropriate travel for the load you put into it. Usually bouncing is more severe on under sprung cars that are over damped because the shocks have been cranked to full rebound stiffness, in most cases in an effort to prevent shock bottoming from being under sprung.
Mike
Mike
#102
BC coilovers to me never satisfied my needs. I had 18k/16k and it just never felt stable or made me confident in the corners. After switching over to Penske 18k/16k I’m blown away and will never get anything less. BC coilovers to me just never felt right and never inspired great handling. Over bumps and dips it bounced bad and I had the adjust like 5 clicks below max. Maxing it out made no difference either and lowering the adjustment made it worse. I’m also on fire hawk Indy 500 tires and it feels absolutely amazing with the Penske coilovers. People forget how heavy this car is. We’re not talking about a 3000 pound car here with a heavy driver your looking at almost 4000 pounds for a sedan.
#103
12/10k here, daily driver on some of the worst roads in the country, Philadelphia PA. HUGE potholes, dps,waves and road imperfections
Been driving it 2 years and put 85k,on the kit I find the top rubber strut mounts only last half as long as the struts.
#104
The Maker
For an R-comp setup, you would want to be in the higher spring rate range to handle the load. I would also suggest the DS series as it will add more initial anti-roll while still maintaining the higher speed damping in am more relaxed range. For a bigger step, the ER series is a great performer, this is what we have been testing the last 8 months or so. It will allow more fine tuning on the low/high speed compression.
Mike
Mike
__________________
#105
Mike
Mike
Hey Figs I know you are very knowledgeable, I just installed 18k/14k spring rate coilovers and R compound tires for the track and I am FBO. I have a track day next Monday but do not know where I should start my dampning settings?
