Installed, F Sport rear sway bar.
Old 06-11-12, 06:39 AM
STGSC400
STGSC400's Avatar
Default Installed, F Sport rear sway bar.
Guys/Gals
Just installed the F Sport rear sway bar on my 08 ISF.
This is a must for 160 bucks. Car feels center and handles great. (handled great before) but for the under 200 buck Price point, This is a must and should be on the 1st of everyones Mod list.
Anyone replace the front sway bar? I did both on my TL and it made a big difference. Will the F sport front Bar fit on the ISF?
Matt
Old 06-11-12, 06:54 AM
flowrider
flowrider's Avatar
Received 1,831 Likes on 1,293 Posts
See the two threads listed below:
https://www.clublexus.com/forums/is-...-sway-bar.html
https://www.clublexus.com/forums/is-...-and-is-f.html
The ISF front sway bar and the F-Sport front sway bar are the same OD, but the bushings are different. If you changed the front bar, IMO you would feel no difference and there would be no improvement. As you have posted, the rear F-Sport bar makes a positive handling change.
Lou
Old 06-11-12, 07:04 AM
STGSC400
STGSC400's Avatar
Thanks Lou.
Any Other Companies make a front Strut bar for the ISF?
Old 06-11-12, 10:03 AM
lexsane
lexsane's Avatar
how long did it take to install
Old 06-11-12, 10:10 AM
STGSC400
STGSC400's Avatar
Maybe 30 Min at the longest. I have a Lift. So that Helps
Old 06-11-12, 10:50 AM
RCB
RCB's Avatar
Sikky also makes an adjustable bar but the F Sport bar works great for a fraction of the price. The extra money saved can go towards Figs Mega Arms which have multiple pickup point for the sway bar. Figs clams that with the Mega Arm the rear sway bar upgrade is not really needed. That being said the F Sport bar + Mega Arm should be more then enough. I'm waiting on Figs tow links to show up befor I install my Mega Arms so in the mean time I installed the F Sport rear bar yesterday as well. I have to say that it is a nice complement to the grip provided by the 305 PSS tires I'm running.
I plan on just leaving this bar installed with the Mega Arms and Toe Links.
Old 06-12-12, 01:27 PM
aWorkOfArt
aWorkOfArt's Avatar
Anyone installed this on a 2012, wondering if the rear sway bar was changed out compared to the previous years. if someone can confirm please. If its the same as the previous years, this mod is going on my to buy list, thanks guys !
Old 06-12-12, 02:02 PM
ERDoc74
ERDoc74's Avatar
same as prev years.... you NEED this mod!
Old 06-12-12, 02:07 PM
ISF001
ISF001's Avatar
Originally Posted by STGSC400
Guys/Gals
Matt
Apparently, this is not a mod for the 2012 F owners...
http://www.lexus.com/pdf/models/full...ries_chart.pdf
File Type: pdf
Old 06-12-12, 03:40 PM
flowrider
flowrider's Avatar
^^^^The rear F-Sport bar we have been using was PN PTR02-53080, it's the old F-Sport Kit for the IS 250 AWD, and was never recommended or advertised by Lexus as being compatible for the "F". A number of folks, noticed it had a larger diameter than the Rear F bar, and thought it would fit. But again, it was never intended by Lexus to be used on the ISF.
Lou
Old 06-12-12, 04:04 PM
aWorkOfArt
aWorkOfArt's Avatar
Thumbs up
Awesome ! Thanks for the heads up, it now has been added to my to buy list
Old 06-12-12, 05:22 PM
ISF001
ISF001's Avatar
I'll be a follower here. Let me know how if there are any issues with your installation on the 2012.
Old 06-12-12, 05:58 PM
caymandive
11 Second Club
caymandive's Avatar
The F Sport bar is about the only other mod I may consider doing. The SIKKY bar looks good, but it's overkill and costs significantly more than the F Sport.
Old 06-12-12, 08:55 PM
STGSC400
STGSC400's Avatar
For the Cost and the fact my car will most likely never see a track i went with the F-sport. If you where on the track a lot and needed the different settings then i would go with the Sikky.
Old 06-13-12, 03:04 AM
UCrazyKid
UCrazyKid's Avatar
Guys/Gals
Matt
Adding more front bar will increase understeer in a car that already has that problem.
Worked on the TL because it is a front wheel drive car.
Quick Reply: Installed, F Sport rear sway bar.
