Pic of your IS-F - RIGHT NOW!
Old 07-22-14, 10:06 AM
  #1636
ISFpat
ISFpat's Avatar
Originally Posted by jiggahwh0
from Spocom this passed weekend
wh0re lol
Old 07-22-14, 12:01 PM
  #1637
shahir18
shahir18's Avatar
Old 07-22-14, 12:12 PM
  #1638
Meraki Autoworks
Your #1 Lexus Vendor
Meraki Autoworks's Avatar
^^ clean.. usb is always my favorite color & those oem wheels. are you on spacers?
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Old 07-22-14, 01:47 PM
  #1639
jiggahwh0
jiggahwh0's Avatar
Originally Posted by ISFpat
wh0re lol
LOL not even
Old 07-22-14, 02:30 PM
  #1640
shahir18
shahir18's Avatar
Yes I am, 15mm all around
Old 07-22-14, 02:45 PM
  #1641
I8ABMR
I8ABMR's Avatar
Are you dropped too? What set up/springs? also are the tires stock size or the 245/275 combo?
Thanks. Car looks amazing. When I see pics like that I feel like spacers just make like easier than a set of aftermarket wheels with hub rings and possible quality issues and the added unsprung weight
Old 07-22-14, 03:07 PM
  #1642
shahir18
shahir18's Avatar
Dropped on the front only with Swift Springs, stock tire specs... I do plan on getting 245/275 combo in the future (after tires are worn)
Old 07-22-14, 03:22 PM
  #1643
Lmood
Lmood's Avatar
Looks good. Is that the lip from jl motoring? What brad spacers are you running?
Old 07-22-14, 03:25 PM
  #1644
shahir18
shahir18's Avatar
lip is not from jl-motoring, spacers are by b2designs
Old 07-22-14, 03:39 PM
  #1645
Meraki Autoworks
I would've went that spacer route but after looking at some threads on the forum and how spacers fail some people I got scared and went with aftermarket wheels.
__________________
Orange County, CA
Old 07-22-14, 03:52 PM
  #1646
Vervish
Vervish's Avatar
H&R adapters with extended studs pretty much eliminates the danger...based on my research. I just ordered them and plan to install along with the swift springs sitting in my garage at home.
Old 07-22-14, 04:46 PM
  #1647
Reaper21
Reaper21's Avatar
Spacers fail when people are stupid. If you buy spacers WITHOUT built-in studs, and replace the stock studs with extended ones and torque down the wheel as you should, there is no reason whatsoever why the spacer should fail.
The spacers WITH built-in studs have the chance to fail since you are relying on the 5 nuts holding the spacer to the hub not to come loose.
Old 07-22-14, 05:08 PM
  #1648
ISFpat
ISFpat's Avatar
There's no logic in this.. A spacer with built in studs bolted onto stock studs are bolted down the same and create less leverage issues over extended studs on stock hubs which are now double the length of stock sized studs.
I have tracked, beaten down and DD'd a car on spacers with built in studs for over 30k miles and I removed them a few months ago and it came off without any issues as if it was never there.
This is why extended studs not built into the spacers are becoming less popular, its not easily reversible and its been proven that built in studs into spacers just as reliable or more reliable.
Ive had spacers on my ISF that had built in studs and drove on it just fine the whole time I've had it on.
Old 07-22-14, 07:37 PM
  #1649
ISFPOWER
ISFPOWER's Avatar
+1
had spacers on all my previous cars, driven all super hard, older car had over 100k miles on spacers. never even a small problem..no vibrations, nothiing.
Old 07-22-14, 07:44 PM
  #1650
shahir18
shahir18's Avatar
I agree with ISFpat and ISFPOWER - I have been riding on spacers with no issues, plus the ones by b2designs are really good quality!
Quick Reply: Pic of your IS-F - RIGHT NOW!
