2011 USB to iPhone 4s to play Pandora
Old 02-12-12, 04:13 PM
fraguada1
fraguada1's Avatar
Default 2011 USB to iPhone 4s to play Pandora
IS F 2011 w/ Mark Levinson system. Just got an iPhone 4s. I want to play Pandora using the USB connection but I get no sound. I can make phone calls using Blue Tooth but can't play music. I'm using the earphone connection to play for now but I need the USB to charge it. Any ideas how to connect through USB or Blue Tooth to Pandora? Thank You for your time.
Old 02-12-12, 05:14 PM
DCoolBeans
DCoolBeans's Avatar
Did you make sure the media volume is all the way up on your phone?
Old 02-12-12, 06:46 PM
Diesel350
Diesel350's Avatar
Why not play Pandora through Bluetooth Audio and forget using any cables?
Old 02-12-12, 07:52 PM
LBmtb
LBmtb's Avatar
I have issues with Pandora and the USB cable. Pandora via bluetooth works fine though.
Old 02-13-12, 02:24 PM
fraguada1
fraguada1's Avatar
How I connect Pandora with blue tooth.
I go to BT and try to connect to but it found no device and time out. The telephone works fine.
Old 02-13-12, 02:28 PM
fraguada1
fraguada1's Avatar
When I connect with the USB it shows a small icon that said iPod..
Old 02-13-12, 02:43 PM
mikes rx
I use "..." ....... a lot
mikes rx's Avatar
IIRC you have to the phone up a second time, but this time as an audio device (basically, the car sees it as two devices: phone device and audio device, even though it's the same iphone)
I believe everything is the same setup wise as doing the phone setup, only I believe it utilizes a different access code, specific for audio device vs phone device.
It took me a short while, paying particular attention to the owner's manual, to get it to work on my car, but now that it's setup everything works great.
Old 02-13-12, 09:32 PM
fraguada1
fraguada1's Avatar
I want to thank everyone for taking their time to answer. I linked to Blue Tooth like you guys suggested. Not only hold and resume the song when I go in/out. of the car, I can also control the volume and change songs from the steering wheel. All I had to do was delete the device that I created and connected again. Wow I'm Happy
Lisangnt
04-26-17 09:16 AM
DBCOM
NX - 1st Gen (2015-2021)
10-27-16 09:30 PM
JNGold
11-12-11 08:19 PM
DKKis350
01-07-11 05:47 PM
Quick Reply: 2011 USB to iPhone 4s to play Pandora
