Water Pump leaking - Page 3 - Club Lexus Forums
Water Pump leaking
Thread Tools Search this Thread
Old 05-20-11, 08:08 PM   #31
lscale
Might it be that it is the gasket failing and they replace the pump too as a precaution?
lscale is offline   Reply With Quote
Old 05-20-11, 09:22 PM   #32
digger08
Quote:
Originally Posted by Joe Z View Post
I wonder who manufacture's the Water Pump for Lexus ????
Can any of you guys that replaced, get a close look at the failed pump for stampings??
Joe Z
Not sure?...my guess is Aisin or Denso?
digger08 is offline   Reply With Quote
Old 05-21-11, 08:02 AM   #33
Civic Si-r
Has anyone looked to see if there is a TSB on the water pump for the affected year vehicle?????
Civic Si-r is offline   Reply With Quote
Old 05-21-11, 09:07 AM   #34
digger08
Quote:
Yes I have looked and there is not one....yet - as of the last Lexus posting date of May11
Old 05-22-11, 10:05 PM   #35
lobuxracer
Tech Info Resource
lobuxracer's Avatar
There won't be an LSB for this. It's easy to see when there is a problem, and it will only be addressed if there is evidence of a problem. The procedure is in the FSM, and the new part is likely the only one currently available, so you'll get the new part iff your unit fails, so there's no need for any kind of service bulletin.
Service bulletins address problems requiring a procedure or inspection not included in the repair manual. This is just a simple warranty claim for any failures.
BTW, checked mine - zero evidence of any leakage.
lobuxracer is offline   Reply With Quote
Old 05-23-11, 08:45 AM   #36
crazymikie
I looked at my car- 23k miles and the fluid is low. I couldn't see any dried up antifreeze, but I need to look when the car isn't in the garage (lighting is bad).
crazymikie is offline   Reply With Quote
Old 05-23-11, 01:12 PM   #37
James7
^ same here ... 34k and fluid is at low - i gotta check this out now
James7 is offline   Reply With Quote
Old 05-23-11, 05:58 PM   #38
lobuxracer
Tech Info Resource
lobuxracer's Avatar
My fluid was at the low mark after 47k miles, but there is no pink anywhere outside the reservoir.
Old 08-17-11, 05:35 PM   #39
riboflavin
good info. I better check mine this weekend.
riboflavin is offline   Reply With Quote
Old 08-17-11, 07:00 PM   #40
CalitriSC
Good thread, I will need to go check mine now. Im at 27k miles currently.
CalitriSC is offline   Reply With Quote
Old 08-17-11, 07:13 PM   #41
spddemon
spddemon's Avatar
So let get this straight Lexus is installing the new upgraded pump ? By the way thanks for the heads up.
spddemon is offline   Reply With Quote
Old 08-17-11, 07:30 PM   #42
lobuxracer
Tech Info Resource
lobuxracer's Avatar
The old part number is superceded by the new one. You couldn't get the old part even if you wanted one.
Old 08-18-11, 12:07 PM   #43
Juanca
Juanca's Avatar
I'm glad I saw this thread today, I just checked my car and there it is, a big pink crust! Coolant level is a bit under low, I'll be taking the car to the dealer this week. Thanks digger.
Juanca is offline   Reply With Quote
Old 08-18-11, 08:04 PM   #44
streetx
i know the 4 cylinder toyota motors have this issue too. When i had my xb, some people reported this issue. some think it is the coolant that eats away the seal but no one has confirmed it yet
i quickly checked mine today and didnt see any pink crust but my coolant level it low. Guessing it normal after two years of slight evaporation out of the resevoir
streetx is offline   Reply With Quote
Old 12-06-11, 12:51 PM   #45
VtotheJ
VtotheJ's Avatar
Reviving this thread... I have no leaking, I don't see any pink at the bottom of my engine bay, but the coolant level is LOW. does this mean I still need to get the water pump replaced? And this should be covered under factory warranty right?
VtotheJ is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
step-by-step timing belt replacement LS430 jimdwright LS - 3rd Gen (2001-2006) 97 01-22-17 11:28 AM
Sunroof / Moonroof Leak draco RX - 2nd Gen (2004-2009) 34 11-18-16 04:24 AM
How to fix powersteering leak on 98-2000 LS400's Zero_One LS - 1st and 2nd Gen (1990-2000) 68 09-30-16 02:42 PM
Coolant drips out of reservoir cap end 2003 ES300 fade41 ES - 1st to 4th Gen (1990-2006) 14 04-20-16 10:13 AM
Check your water pump thequickad GX - 2nd Gen (2010-present) 7 03-21-16 10:30 AM
Tags
350, add, clublexus, coolant, gs400, is350, isf, leak, leaking, lexus, losing, pink, pump, rx, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright © 2000-2016 Internet Brands, Inc. All Rights Reserved
