CD/DVD Changer HELP!
I did a search on ClubLexus, IS300.net, and google, and found nothing close to my issue.
Today I decided to install the Prestigous Society DVD/Nav overide. I installed the unit and it works partially. The Nav overide allows me to input the destination while in motion, but I can't get DVD to work.
I have Braveheart in the DVD changer for over a year now and play it every once in a while when I'm sitting in the car for a long period of time. While testing the unit I can't seem to get the DVD to play, eject, insert dvd or cd or whatever the case is. The DVD / AUX screen shows DVD in slot 1 and CD in slot 2. I can't toggle between the 2 to play either one. It's like it's stuck. I disconnected the battery for a few minutes and that didn't do anything. I do not hear any noise come from the changer (trying to see if it's even got power). I assume so if I can use all the other buttons. I decided to uninstall the prestigous society unit and go back to stock and nothing is different.
I can switch between AM/FM/SAT/AUX without any problems. I have a 2008 Lexus IS-F with Mark Levinson.
Your help is appreciated.
Thanks!
Thanks!
If you have it back to stock, I suggest you head to the dealer for a warranty repair. The Nav system is $$$$ you don't want to do too much on your own.
