KW V3 Rebound/Compression settings for IS-F
Old 04-26-15, 08:23 PM
  #31
JDMV8
JDMV8's Avatar
I'll bump this thread back up instead of starting a new one.
I experimented with many compression and rebound settings and finally hit the sweet spot.
from full stiff, 6 clicks for rebound (rears and fronts).
from full stiff, .75 turns for compression (rears and fronts)
I have a sikky rear sway bar as well set on full stiff.
The car does not understeer at all, and is easily tail happy with a touch of the throttle.
I'm not Jeremy Clarkson when it comes to oversteer, but I do prefer it to oversteer.
My review is based solely on back road driving...planning to take it to the track this summer.
Old 04-26-15, 09:45 PM
  #32
Meraki Autoworks
Your #1 Lexus Vendor
Meraki Autoworks's Avatar
^ you just hit my sweet spot, I forgot I messed with my settings and now I can adjust these bad boys >
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Old 04-27-15, 05:58 PM
  #33
SoulFreak
SoulFreak's Avatar
Originally Posted by T-Rex06
^^ I'd upgrade the tires first. You can go 255/35 front and 285/30 in the rear if you're keeping stock rims. It'll make a huge difference.
Terrance
Can this size of tire fit well on a MY 2011. Will it rub? I can only imagine the amount of grip you'll obtain! How about weight? Will it significantly slow the car down?
Old 03-14-16, 06:28 AM
  #34
Rus197
Rus197's Avatar
Hello to everyone!
My name is Mikhail and I'm russian owner of an ISF for the last 4 years and I watchin all the forums and your articles and comments - appreciate thi kind of content, it's really helpful!
Right now I'm struggling for info about KW V3 springs replacement options. Previously I used swift springs on my stock shocks and after I have change it for KW V3. After yeaar of using it seems to me too soft, the spring rates are 11/8 kg's, but Im looking for 14/10 or higher to make improvements. I know that swift springs has their spring set up for BC coils, but what about KW? What setup swift can offer for KW, is it possible to make this replacement?
Thanks in advance and best regards!
Old 03-14-16, 07:49 PM
  #35
I8ABMR
I8ABMR's Avatar
This is honestly one thing I didnt like about coil overs. They are great because you can adjust them but they never felt as dialed in as the oem set up minus the roll when I really pushed the car. It would either over steer, understeer , ride like ****, or just feel too soft. It just created a chore for me to get it set up only to realize I was set up for the roads I drove and not the ones I would come across . Then when I had the electronic damping force controller mounted in the arm rest I found myself adjust my suspension as I drove for the corner I just went through LOL.
I would do coil overs later if my car became a full on track car or when I feel the need to step up the handling . So far the handling with these monster 255/295s is solid, but I want less roll and tighter steering. Will probably be doing the steering ECU down the line as well. Coil overs for me is opening a HUGE can of worms
Old 03-14-16, 07:50 PM
  #36
I8ABMR
I8ABMR's Avatar
Originally Posted by Rus197
Hello to everyone!
RR Racing, BC Racing, Ohlins, and Penske. Lots of options
kauaian
03-17-16 11:28 AM
ISFPOWER
IS F (2008-2014)
81
12-14-15 08:20 PM
Ltaboso
IS F (2008-2014)
03-05-15 06:01 AM
Mikifiki
IS F (2008-2014)
24
01-27-13 04:56 PM
Dave600hL
IS F (2008-2014)
01-24-09 11:41 PM
Quick Reply: KW V3 Rebound/Compression settings for IS-F
