HKS SSM IS F Exhaust Pics Inside!
Old 11-12-10, 05:08 AM
caymandive
11 Second Club
caymandive's Avatar
Wow these are crazy looking and as Brad said look very similar to a French horn. I like the idea of adding the "Helmholtz Resonator" design but not a fan of the added pipe length.
Subscribed
Old 11-12-10, 06:39 AM
yemgi
yemgi's Avatar
The quality looks fantastic. I just wondered why they have only 1 pipe at the exit if the want to keep the standard stacked diffuser
The design is very similar to the Suruga Speed exhaust, it should keep the noise level very low and if the power gain is similar as well it would be a very interesting option, Suruga being quite expensive with the shipping and taxes from Japan
Old 11-13-10, 08:13 AM
death
death's Avatar
Sick, subscribed to see the final results.
Old 11-13-10, 10:49 AM
ISMAN250
ISMAN250's Avatar
That is one gorgeous and crazy exhaust. Any videos?
Old 11-13-10, 11:34 AM
Gymkata
Gymkata's Avatar
Hmmm...looks very interesting...subscribed.
Old 11-13-10, 01:32 PM
HEWITT
HEWITT's Avatar
Interesting !!!!!!
Old 11-13-10, 01:40 PM
carlosg
carlosg's Avatar
It doesn't seem that heavy, so probably will be a weight saver also
Old 11-13-10, 02:28 PM
ExclusivIS
ExclusivIS's Avatar
Nice Darrel!
Old 11-14-10, 10:03 AM
zojirushi
zojirushi's Avatar
Is this going to bolt up to the oem mid pipe. If so, does that mean it retains the factory pipe diameter?
Old 11-17-10, 10:54 AM
maj75
maj75's Avatar
How long does it take to install this exhaust
Was expecting a report before this...
Old 11-17-10, 11:28 AM
mikefate
mikefate's Avatar
Should take less than an hour with a lift. Doesn't look too complicated.
Old 11-17-10, 07:19 PM
FIGS
The Maker
FIGS's Avatar
Well I am not sure what to think. Based on the proto I built with straight HKS Ti cans there is not much drone at all with a straight muffler, so not sure what tone they are shooting for. The extra bends will add some cancellation, basically like a muffler outside the muffler, but I think with the added bracing etc, its going to be very close to stock weight unless they used a thin wall Stainless, like 0.032".
Props to them for doing a stainless casting for the stock ball flange, I just had custom ball flanges spun, and for robotic welding everything. The hollow hangers are also something I tried to do also to save weight.
I am going to make a bet that given the investment its going to be north of $1K but maybe it will be a nice surprise. The speculation about the musical instrument shapes adding to the tone are somewhat true however not in the classical sense of an instrument. An instrument has a gradually tapered design that amplifies sound through constructive resonance. This design is trying to do the opposite and it needs more tubing length to achieve more destructive interference. Most of the tone will come from the difference in length of the two sides or the syncopation of the resulting two tones out of each side. It could sound pretty interesting if the two sides are delay enough WRT to eachother.
To comment on the performance of my straight pipe Ti design, it netted peak gains (at peak RPM) of 8WHP. Things were pretty well offset from 3500 up so a good area of gains overall. Not much you say, but keep in mind the weight savings is much more important that the net numbers. The diffuser effect is also not measured on a dyno either so that bears mentioning.
Tracking this thread to see of people are still interested in an axle back design and what the end price will be. Thanks for the post and pics.
Fig
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Old 11-18-10, 10:16 AM
UCrazyKid
UCrazyKid's Avatar
Well, it sure is pretty. I'll hold judgment until I see some dyno numbers and a sound clip.
Old 11-18-10, 08:35 PM
N54MPower
N54MPower's Avatar
Thanks for all of the kind words and interest in the R & D being done by HKS for the IS F exhaust. The folks at HKS are well aware of this thread too.
I'll be picking up my car either tomorrow or Saturday from them. Once I go over all of the details I will post what I know.
Old 11-19-10, 04:56 AM
carlosg
carlosg's Avatar
try to get a sound clip
Quick Reply: HKS SSM IS F Exhaust Pics Inside!
