Creaking driver's seat
Old 11-08-10, 07:43 AM
qsz06
qsz06's Avatar
Passenger side creak here. Will check bolts today.
Old 11-08-10, 08:52 AM
Joe Z
Joe Z's Avatar
Received 1,058 Likes on 586 Posts
Originally Posted by caymandive
I just did all 4. They all seemed to have a tiny bit of slack in them and if I can remember correctly I think the front left bolt was the problem child.
^ Thanks for the info....
^^ Mine creaks when empty.....
Old 11-08-10, 10:31 AM
hahahaf
hahahaf's Avatar
mine only when empty as well
Old 11-09-10, 09:28 AM
qsz06
qsz06's Avatar
Mine only does it when wifey is sitting in it. I tell her it is a sign that she should gain some weight !
Old 11-10-10, 08:44 AM
qsz06
qsz06's Avatar
Bolts on passenger side were loose . Two out of four that is. I removed all four and put a small amount of loctite on them because this is the second they have become loose! Did Lexus put any kind of material on threads to eliminate this? My driver side gets way more use and no problems there.
Old 11-10-10, 12:33 PM
Bulls23337
Bulls23337's Avatar
me too! i'm glad i'm not the only one. it sounds like a busted mattress kinda creaking sound!
Old 11-11-10, 04:48 PM
UCrazyKid
UCrazyKid's Avatar
Thanks for the heads up everyone, 14mm and 2 minutes and it is all fixed.
Old 11-11-10, 09:30 PM
hahahaf
hahahaf's Avatar
which bolts are we talking about exactly
Old 11-11-10, 11:06 PM
UCrazyKid
UCrazyKid's Avatar
The four bolts that hold the seat rails to the floor.
Old 11-12-10, 08:47 AM
Joe Z
Joe Z's Avatar
So I finally checked my bolts and they were all tight (surprisingly)
BUT - we did solve the creak by bending the door frame in, by the top window rail.. about 1 mm..
Crazy I know..!! but it worked.. since the glass is now snug against the frame gaskets.
I got tipped off by a Master Tech on some “creak/vibrating fixes”
Joe Z
Old 11-12-10, 06:40 PM
gqisf
gqisf's Avatar
I now have no creaks! The rf and lr bolts were super loose. I put some thread lock on the bolts when putting them back in so hopefully this won't be a recurring affair. Thanks for info fellas!
Old 11-28-10, 12:43 PM
itsmike177
itsmike177's Avatar
Glad this was posted in the forums. I just couldn't pinpoint where this creaking noise was originating from, so decided to just tight down all eight bolts on both front seats and the squeaking noise is now gone.
It didn't seem like any of the bolts were loose though, so maybe the 0.5-1mm of tightening worked.
Old 09-16-11, 12:44 PM
jkeifer3
jkeifer3's Avatar
Originally Posted by MRxSLAYx
Tighten your seats guys. The 14 wrench in the trunk will do the job. Over time, vibrations will cause the seats to get loose. Quick DIY fix
MRxSLAYx, do you do this from inside or from underneath the car? Thanks.
Old 09-16-11, 01:43 PM
Joe Z
Joe Z's Avatar
Lightbulb
4 Bolts on each seat, covered by the black plastic caps....
~ Joe Z
Old 09-17-11, 12:34 AM
jkeifer3
jkeifer3's Avatar
~ Joe Z
Much grass!
wallaceb
RC - 1st Gen (2015-present)
02-28-19 05:30 AM
UnSub
10-10-11 05:57 AM
YJacketISF
IS F (2008-2014)
13
07-04-09 02:36 PM
JZCHAOS
SC- 1st Gen (1992-2000)
11-13-08 05:56 PM
ph00ny
08-29-06 09:07 PM
Quick Reply: Creaking driver's seat
