Aggressive fitment IS-F pics!
#873
Wish my ISFs could look like everyones here, so clean!
Looking to pick up a set of wheels 19x8.5 +22, 19x9.5+ 22, would the rears fit fine? I see a lot of people running 10.5 +35 on 265/35, which is pretty much equivalent to 9.5+22 right?
How about the front? They should fit fine too right?
I went through this whole thread and a person asked about the same specs, but nobody replied so I had to make another post!
Please help wheel gurus!!!
#875
Front will be fine, except it'll rub the liners towards full lock. The rear will rub with guard roll with. I have 255-35 Potenza S001's which are big square for that size & they rub with -2.5deg rear camber.
While the position of the outer rim may be similar to a 10.5 +35, the fact that it's a narrower wheel means the tyres sit more square (not as stretched) which affects the tyre clearance.
#876
Anyone know if the below will rub with rolled guards & max -2.5deg rear camber?
19x9.5 +25 with 235/35
19x11 +37 with 275/30
I currently have 19x8.5/9.5 +22 all round & the narrow rears with 255/35's are rubbing a lot with passengers or hard cornering, which can be a bit annoying.
#877
20x10.5 45 offset 295/25/20 rear 4 in lip
Fits perfect no fender roll or shaving only rubs on big dips and reverse full lock
Hope this helps.
ThisOldNSX (11-04-22)
#880
I have those specs.
Front:: 19x8.5 +18 with 245/35/R19
Rear: 19x9.5 +22 with 275/30/R19
Based on what you said, I think the front would rub a lot or may not even clear the calipers..hmm
B8bydesign (02-11-20)
#884
-Josh
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Orange County, CA
#885
