What oil to use in rear-diff?
Is it true that, from model year 2011, the ISFs use different differential oil? There was a debate going on in a local forum and it was reported that Toyota Korea confirmed '11 ISFs have differential oil that is "LSD-compatible."
I thought Torsen diff does not need "special oil"?
Thought I'd follow up on this. So I'm at 58,000 miles about 8 months later. I'm starting to do some of the 60K mile services. The first one I decided to do was replace the rear diff fluid. It was an easy DIY. The IS350 DIY thread really helped. There are some great pics on Page 4 by JoeZ. https://www.clublexus.com/forums/is-...nge-diy-4.html Thanks Joe!
I was surprised at how dirty the diff fluid was, especially when it first started coming out. The magnetized drain plug had the typical glob of metal shavings on the end. I stuck my finger in the drain hole and dragged out more of the shavings before I plugged it back up to refill. The fluid pump was great in putting fresh fluid back in. I got tired of pumping though before I got 1.5 quarts back in.
My dealer charges $85 plus tax for this service. It cost me $35 plus tax. I bought two quarts of Lucas Synthetic gear oil, 75W90, for $25. Plus a $10 fluid pump. All the other tools, including the 10mm hex socket, I had at home. One tip is that you'll need a 4 in extension for your ratchet to get around the F's stock exhaust in order to reach the plugs. Taking my own sweet time, it took me 45 min to an hour from start to finish, including clean up.
I don't track my F and my fluid was still pretty dirty. So I'd highly recommend those with the 2010 and up to get this done at 60K - and sooner if you track it.
I have an 09 ISF, so it does not.have the true LSD from the '10+ ISF.
Will be changing the differential fluid this week. Trying to decide if I should stick with OEM fluids for try motul gear 300 75w-90. I looked up this motul gear fluid using their lubricant advisor.
Anyone else have experience with this motul gear 300 75w-90?
Tech Info Resource
As long as it meets GL-5 requirements, it will work fine.
Differentials have a 500k mile service life with the factory recommended lubricant. Spending more money on name brands only makes you feel good. It does not add to the service life of the unit in any significant fashion unless you are pushing it to its limits routinely. IOW - if you don't track the car, it won't matter what brand of gear lube you put in the differential as long as it meets GL-5 requirements.
https://www.clublexus.com/forums/gs-...ge-w-pics.html
Tech Info Resource
pretty much the same thing. Remember always open the fill port first, just in case for some reason it seizes. Because if you drain the oil first then find out you cant open the fill, you've got a big problem
Sp went through the owners manual and I cant find anywhere where it mentions anything about the differential. So what weight are you supposed to use on a 2008?
Also do you guys know the part number for the rear differential crush washer for toyota?
