Transmission weird behaviors
Guys lately i have been noticing weird transmission shifting behavior where it's shifting very sluggish and at times it won't upshift....For instance in auto mode car is in 2nd gear and i am trying to accelerate....RPM will go all the way to 6k or above without an Upshift...Sometimes i have to manually shift it to get it back to normal shifts.
Another behavior which is very much Reproducible....At 80 let's say i step on it on auto mode....So it downshifts to 6th, now during upshift going from 6th to 7th...RPM's Jump about 500 RPMs before coming down to Normal RPM range for 7th gear.....I''ll post a video soon
Let me know if other F owners noticed this.....My F has about 26k miles (Never tracked or abused)
Do you have the sport mode on in the first situation?
Tech Info Resource
Sounds like a fluid level problem in the gearbox. Did they disconnect the cooler lines when they did the engine? They might not have topped off the gearbox correctly.
http://www.lexusfforum.com/forums/sh...t=transmission
I don't know about the 500 rpm blip, but not wanting to shift out of second has happened to many people. Check out the above link.
Tech Info Resource
I have a similar problem. My car does the 500 RPM jump only when going from 4th into 5th, and only when the car has been sitting with the engine off for over a couple of hours. It does it only the first time going into 5th, then it won't happen again until the next time the engine is off (for another couple of hours). This behavior leads me to believe that it's indeed something related with the tranny's oil level, since it won't happen again once the car has been warmed up, or driven already past 5th gear. My car has never seen the dealer for anything other than regular service or warranty work (rearview mirror, blown subwoofer, faulty ML touchscreen, and tach needle issue), and I purchased it brand new back in June 2008.
I took the car to the dealer for this issue, and both the mechanic and his supervisor agreed that this was normal behavior. I told them how come this is normal if it's been happening since last month, not since the beginning... they failed to answer that. I made sure that they entered my concern in their system (which is nationwide), so if I have a tranny problem in the future my concern was already documented.
Off the record, the mechanic said that he did notice the problem. He also said that it'd be really hard for Lexus to aknowledge the problem because they'd have to start an investigation on all IS-Fs, and if they confirm the issue with the tranny they'd have to replace it completely, apparently this tranny needs to be replaced in full. The warranty is good for 7 years, so let's see what happens.
