Old 12-15-14, 03:49 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Tires and Wheels Guide
Print Wikipost
Do your front tire look like this? Tire wear and alignment thread
Old 05-10-10, 11:18 AM
UCrazyKid
UCrazyKid's Avatar
Default Do your front tires look like this? Tire wear and alignment thread
So my Michelin PS2 have ~18,000 miles on them. The rears seem to be wearing perfectly even but the fronts are shot on the inside edge and the outside edge is wearing quite a bit too.
I know I need new tires NOW so please spare me with the "you waited too long".
Tire pressure has always been monitored and adjusted appropriately. The car was aligned multiple times as a result of the inherent right side pull until it was fixed by replacing the brackets for caster (warranty).
Is the factor alignment what is giving me strange tire wear on the front? Should I have the toe changed when I align it for the new tires?
Thanks in advance.
Pics:
Front: (both left and right look exactly the same)
Center wear, probably 1/16th till the wear bar.
Rear: Nice and even.
Thoughts?
Old 05-10-10, 11:31 AM
Evil Teo
Evil Teo's Avatar
when was the last time u had an alignment?
can u get the specs of your alignment from the last one?
i think this will provide more information for others to help you determine what is causing the problem. also let me know how it goes cuz i might be in the same situation.
Old 05-10-10, 12:40 PM
UCrazyKid
UCrazyKid's Avatar
Car has 17K+ miles on it and alignment was done at the dealer at ~10K to factory specs. I do not have the print out, so no help there
Old 05-10-10, 01:44 PM
Evil Teo
Evil Teo's Avatar
any suspension mods after u had ur alignment done?
Old 05-10-10, 01:50 PM
houstonT
houstonT's Avatar
This is NORMAL (unfortunately).....my 08 MM ISF had this same issue, I was lucky and was able to convince the Regional Mgr to replace my front tires (along with 4 new wheels due to the brake pitting). Since that time, they have stopped doing both afaik.
Just today (ironically), on my 09 SP ISF I noticed that the fronts were starting to wear at the same rate/pattern. I have right at 9,200 miles.
Not sure we can do anything about it.
Peter
Old 05-10-10, 03:15 PM
ISFer
ISFer's Avatar
Andy, Is it possible that this wear is due to 'spirited' driving?
I know myself that it's tempting to corner faster since the F handles so well.
Just a thought.
If this is due to poor alignment or poor parts on the car from the factory, then I'm not pleased about that at all.
I went thru a similar issue on my '03 Infiniti Coupe which exhibited similar issues to the 350Z front suspension issues at the time. Trouble with that was that Infiniti didn't ever acknowledge the problem with the Infiniti coupe like they did with the Z.
After 3 sets of tires and countless alignments, and some lamebrain excuses, I got rid of it....
Colin.
Old 05-10-10, 03:43 PM
tryama
tryama's Avatar
My wheels looked the same way at ~18k. I would have never noticed but I put some new suspension in. Before that, everything was stock.
Old 05-10-10, 03:54 PM
UCrazyKid
UCrazyKid's Avatar
Totally stock suspension. I know the outside wear is likely from spirited driving as suggested but that doesn't explain the inside wear. I guessing toe and know these cars are very limited on their suspension adjustments. I don't want to give up turn in for tire wear as I like how the car handles and still feel 18k miles is acceptible for an extreme performance summer tire. I guess this is normal. Sure beats the 10k miles I used to get on the rears of my 911.
Old 05-10-10, 05:15 PM
surga7
surga7's Avatar
It happened to mine, I brought the car to Pepboys in Rosemead, they said it was the tow alignment. So far so good until now.
Old 05-11-10, 07:49 AM
nuttybar08
nuttybar08's Avatar
The toe on my car was significantly off but I still managed 25K miles on the stock Bridgestones. Correcting the toe settings hasn't fixed the inherent right side pull so my next dealer visit will be a warranty call for the revised caster brackets.
Old 05-11-10, 02:53 PM
UCrazyKid
UCrazyKid's Avatar
It sounds like in general that the Bridgestones last longer than the Michelins.
Old 05-11-10, 03:50 PM
n0th1ng
n0th1ng's Avatar
i have simliar tire wear but not that bad compared to urs..
i flipped my tire after about 15k miles to even those out..
its may common for ISF to do that..
Old 05-11-10, 07:20 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,849 Likes on 2,334 Posts
Mine showed cord on the inside at ~23k. I like the turn in, and 23k is acceptable to me. Otherwise I'd be adding a touch of toe in. The rears are still doing well and are still legal. They'll probably make 30k despite two track weekends on them.
Old 09-11-15, 10:31 PM
dbs600
dbs600's Avatar
Any updates, Gentlemen?
Currently experiencing same.
It's wrong we're not warned to flip tires!
Lexus should warranty all such premature wear.
Old 09-11-15, 11:57 PM
NSXGuy
NSXGuy's Avatar
Look for thread on the Figs #2 LCA bushings.
Quick Reply: Do your front tire look like this? Tire wear and alignment thread
