Mobil 1 0W-30
Old 08-09-09, 05:47 PM
bnizzle87
bnizzle87's Avatar
Default Mobil 1 0W-30
Has anyone switched to this Mobil 1 0W-30 product? Apparently it is suppose to be more fuel efficient and better for those vehicles that already use 5W-30. It is a little more expensive, but that comes with the "advanced" anything label. I was just wondering if it is worth switching from what Lexus and its factories only require that our vehicles use the 5W-30 oil.
Old 08-09-09, 06:03 PM
gs400998
gs400998's Avatar
I just changed the oil in my IS with 0W-30. Recent thread about oil:
https://www.clublexus.com/forums/is-...-is-using.html
Old 08-09-09, 06:55 PM
n0th1ng
n0th1ng's Avatar
I know a friend of mine that uses that oil. he is a BMW tho.. he says its pretty good. but nvr heard anything on lexus engines...
i doubt that going lower weight should effect anything to the car. i once used 5-40 for 5k miles that didnt feel any different either. i just had to wait a bit for my car to heat up a bit.
Old 08-09-09, 09:54 PM
MRxSLAYx
MRxSLAYx's Avatar
Not an expert on the subject but i wouldnt recommend 0Winter oil if you live anywhere that gets cold. I would think that it would affect cold starts.
Old 08-10-09, 12:08 AM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,849 Likes on 2,334 Posts
The W doesn't stand for winter. In 1911 it did mean suitable for winter use, but now it means a different testing standard has been met by the oil. It's a common misconception.
Originally Posted by Ferrari Club of Florida
Many think that the “W” in 10W-30 means “winter”.
From SAE J300 p.2:
"Two series of viscosity grades are defined in Table (1): (a) those containing the letter W and (b) those without. Single viscosity grade oils with the letter W are defined by maximum low temperature cranking and pumping viscosities and a minimum kinematic viscosity at 100C. Single grade oils without the letter W are based on a set of minimum and maximum kinematic viscosities at 100C and a minimum high shear rate viscosity at 150C. The shear rate will depend on the test method. Multigrade grade oils are defined by both of these criteria....
The W is just a designation of one type of testing vs another.
Old 08-10-09, 12:19 AM
kickin8
2IS/2RX/4RX
kickin8's Avatar
it's the same price @WalMart.....
komobu
06-24-20 11:33 AM
coachz
RX - 3rd Gen (2010-2015)
02-25-19 12:21 PM
MileHIFcar
IS F (2008-2014)
24
02-05-16 07:53 AM
pwrusr
05-11-12 04:08 PM
Zeal3
04-19-09 04:07 PM
Quick Reply: Mobil 1 0W-30
