does anyone know where i can get clear door lenses for when i open the door on the bottom...if another lexus has these would you be able to tell me...i want them clear so i can put some bright led's in them so when i open the door you can see!
I am not sure is your clear lenses same as regular ISX50
you can go to toyota dealer to purchase if it the same as regular ISX50
here is the part number: 81230-47010
My wife's ES has clear lenses. They are exactly the same size and have the same lens pattern as my red ones. I'd bet you could find them at a junkyard.
lowrideraz is correct, the clear lenses on an ES are identical to the IS. You can pick them up from your local Toyota or Lexus dealership. Ebay might even have them. Good luck.
Lou
an 08 es350 at a junkyard?????
riiiiiiiiiiiiiight
unless adolescent teenager takes mom car for a joy ride than i guess the chances of him finding one of these cars are almost slim to none...especially if he is in a rural area
Originally Posted by n0th1ng
the lenses on RX 400 is also same :P
I've tried to find them on ebay but no luck... so i guess dealer is the way to go!
The identical part number is also used on the Toyota Prius, and I'm sure a host of other Toyotas in the lineup.
