BC Racing Coilovers
#92
So I am considering getting a set of BC Coilovers but have been reading what seems to be a lot of people that are unhappy with the spring rates. I want to be able to keep a close to stock ride normally but have the ability to increase the rates a decent amount when I want too. Seems as though 14k/12k is the standard so if above is what I am looking for would 16k/14k be better or even 18k/16k? Any input would be helpful. Thanks.
#93
#94
i think im def. goin to get bc coilovers i just wonder if they make it in the er model..i just like that thought of that external resivour. but i plan on goin with 18k front and 16d rear spring rates..
#95
I have the Fig recommended spring rates on my bc coils. I have them in the box still. Haven't had time to install. Plus this ****ty Nj weather I havent driven the f since before Xmas.
#96
The Maker
No ER model yet. There is no space to take the reservoir out I beleive, but I have been pushing this since I started working with BC.
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
#98
11 Second Club
I just received some BC coilovers with 16k/12k spring rates from FIGS the other day and they look great! Love the black/gold look compared to the colorful looking KW coilovers. Anyway, while I'm preparing to do the install, I did some measurements and found something rather surprising about the stock ride height.
I measured the distance from the fender to the floor down the center of the wheel and discovered that one side of the front sits almost a half inch lower than the other side! Anyone else notice this?
Front Driver side: 26 3/8 inches
Front Pass side 26 6/8 inches
Rear Driver side 26 inches
Rear Pass side 25 7/8 inches
#101
My BC coilovers just came the other day as well but I probably won't have time to install them for a week or more. I will have to wait for a weekend so I have more time I guess but have been considering installing the fronts one night and the rears the next. I can't imagine driving with only the fronts installed for one day would be that much of an issue.
Definitely weird about your measurements.
#102
#103
#104
The Maker
For those wondering the higher rates I suggested for caymandive were based on the additional power output of his car and his comfort level with the OEM suspension. This is another reason I feel that the BC offers a better configurable solution for modded cars over KW since KW wants to control the high speed fluid range and the spring rates to what they spec. I feel that spring rate increase vs valve restriction is a better way to deal with coarse energy transfer when you have more power or more traction.
Fig
Fig
__________________
#105
Received 1,058 Likes
But with these fully adjustable coils, you will be able to fine tune each corner height to the exact same specs / ride height that you like..
Joe Z
