Help installing Illuminated Door sills
Grab it from the side and give it a nice tug, it'll pop out. Then just plug it in and snap them on that's it. Make sure your DOOR switch is turned on, or else it won't turn on. If you don't know what the DOOR switch is, look at where you sunroof switch is there's 2 buttons.
Sorry, it is not quite that easy on the isf. (I think that you asked this question here before and got responses?) Here is the diy:
https://www.clublexus.com/forums/is-...ff-plates.html
2IS OG
I did the install on CrazyMPG's IS-F. To make a long story short, I basically had to do some custom work to bring the lead that's on the driver side of the car over to the passenger side. There's a source on the passenger side, but when it's connected to the sill the polarity is reversed and would turn on when the door is closed and off when the door is opened. That's why I had to run them both off of the driver's side lead.
Javier
Javier
Received 1,064 Likes
The F's only come with Aluminum Sill plates ....
^^ You should have just flipped the connector.....
Javier
Javier
Javier
Javier
Javier
Javier
