Earl's Solo-Bleed for IS-F
Tech Info Resource
Never on any car I've put them on. It's quite a few now.
I had a earl speed bleeder strip in my Hilux's caliper. Scared me. I don't like the Earl design. I like the one with the internal ball & spring.
Russell's.
http://www.russellperformance.com/mc/speed/import.shtml
Russell's.
Speed bleeders are spring loaded. When you unscrew them a tiny bit, they allow for air to exit without the exit of fluid. This way you deal without the mess of bleeding the brakes.
In my opinion, I would want some fluid to exit the system, as brake fluid absorbs water over time, especially dot4. No hurt in flushing out some fluid for new fluid
Received 1,058 Likes
Better to use a pump like Lou and Mike posted.
Tech Info Resource
Anyone using pressure to bleed brakes is dissolving air into the brake fluid unless there is an air/fluid separation piston in the system. All fluid and all solids contain gas molecules. Compressing fluids or solids only adds more gas to the system.
I used to think vacuum was great conceptually for bleeding brakes, but unfortunately there are too many seals far too willing to allow air into the system from atmospheric pressure when the seals fail to seal under vacuum. They weren't designed for vacuum, only for pressure.
Former Sponsor
-Matt M.
^^^^I just did mine last week, and as Lance's first post indicated, the front and rear use the same part number. They worked beautifully for me. And again, I want to thank Lance for his great suggestion.
It's too bad Earl's site and all the reseller's sites are so far behind the times in updating their application charts. There's a lot of sales to be gained, IMHO, if their application charts were up to date.
Oh, I see by your profile that you are not an ISF owner. The ISX50 does indeed use different Earl's Solo Bleeders front and rear.
This thread seems to have your answer:
https://www.clublexus.com/forums/sus...der-is350.html
and here:
https://www.clublexus.com/forums/sus...bleeder-2.html
Lou
and here:
Lou
Hey man thanks for replying to my question. I'm installing ISF brake on my is350. So for some reason the rear bleeder screw has a different thread size then the front. Don't know why but thats the case.
and here:
Lou
and here:
Lou
