What is the rear gear ratio for the ISF
Old 07-29-08, 10:13 AM
SC430inVA
SC430inVA's Avatar
Default What is the rear gear ratio for the ISF
and what gear on the tranny gets you 1:1
thanks
al
Old 07-29-08, 01:25 PM
ISFfan
ISFfan's Avatar
6th gear is 1:1
Old 07-29-08, 06:05 PM
lobuxracer
Tech Info Resource
Senior Moderator
lobuxracer's Avatar
Received 4,079 Likes on 2,472 Posts
Everything you need to know is here:
Old 07-29-08, 10:01 PM
Namir
Namir's Avatar
wow this thing can hit 85 in reverse.... i'd like to see that!
Old 07-30-08, 06:37 AM
SC430inVA
SC430inVA's Avatar
Default thanks lobux
that about says it all.
al
Old 07-30-08, 08:07 AM
DRE1615
DRE1615's Avatar
269mph in 8th gear, that would be insane
Old 07-30-08, 02:47 PM
nuttybar08
nuttybar08's Avatar
Compare the IS-F's rear gear to the M3's 3.846. I know why the M3 needs it (less torque), but what are the odds of getting a slightly more aggressive aftermarket gear on the F?
Old 07-30-08, 09:00 PM
lobuxracer
Tech Info Resource
Senior Moderator
lobuxracer's Avatar
Near zero unless the IS-F starts showing up with the OEM differential in some racing series. The diff for the IS-F is unique among 2IS cars, and only the IS350 diff has the same bolt pattern to mount the unit in the rear subframe. I seriously doubt the IS350's diff is up to the task of handling the IS-F's input for the normal diff service life (300k miles) but you might could put the 350 piece in for a test. It's a 4.083:1 ratio, so it would make the IS-F a tire shredder.
Old 07-31-08, 01:03 PM
nuttybar08
nuttybar08's Avatar
I was thinking something in the 3.23 range.
rselby
IS F (2008-2014)
10-07-16 11:09 PM
darbs242
10-09-14 09:33 PM
Hameed
IS F (2008-2014)
04-26-09 08:04 AM
Lextasy89
IS F (2008-2014)
04-23-08 10:13 AM
4TehNguyen
IS F (2008-2014)
19
03-21-08 07:15 PM
Quick Reply: What is the rear gear ratio for the ISF
