Need a lil help here
I Think You Hold Down The Button. I Know That Is What You Do With The Remote. NOT SURE ABOUT THE WINDOWS. I WOULD TAKE IT TO THE DEALER AND LET THEM DEAL WITH IT. EVERYTHING IS FREE SINCE IT IS UNDER WARRENTY
They just forgot to reset the windows. It happened to me too when I had my tints done. If you take it to Lexus they will charge you like 60 bucks to fix it.
Go to your driver door. Push and hold the driver window switch down for 3 seconds, then hold it up for 3 seconds, then repeat holding it down for 3 more seconds, then up again for 3 seconds. This should re-set your driver window. Then go around to you passenger side door and do the same on that side. If you do it correctly, both windows should work from your driver side master controls.
As far as the doors auto unlocking, all of them unlock if you go from the passenger side door, but not the driver side. I would suggest opening the door for your wife/significant other, and scoring some brownie points, all while only having to unlock the doors once. That's what I have started doing. Good Luck
BTW...Let me know if this doesnt work, and I'll call the shop who told me how to fix mine and figure out the right timing. It's really simple and takes 5 minutes and Lexus WILL charge you for them to fix it.
All doors unlocking from the remote is done at the Lexus dealer..A five minute fix.. Had mine done at the 1000 mile service. Its part of the personalized settings that only a dealer can do
man if your guys dealer will charge you for something so petty like that to fix they must be sharks. when i got my tints done the first time, the guy who did it placed the heat gun to close to the side door pillars and ended up warping them a little bit. I took it back to the dealer here in pembroke pines,Fl and they fixed it for me without a problem. Im sure they could of easily charged me 150 for a new door pillar but they were cool about it. Thats the diffrence between dealers that want to keep customers and ones that just want to make a quick buck. LEXUS OF PEMBROKE PINES is #1 lexus dealership.
jrmckinley
09-04-16 11:13 AM
