MotorTrend First Test - 2008 Lexus IS F
Full article here:
http://www.motortrend.com/roadtests/...08_lexus_is_f/
MT got a 0-60 time of 4.7 seconds.
The car is, quite simply, a monster: Acceleration is brutal, the brakes are wicked-strong, and handling grip is immense (a Sport mode for Lexus's VDIM stability-control system increases steering weight, boosts throttle response, and allows the tail to step out usefully before the electronics step in; Lexus says Sport produces faster lap times than switching off the system altogether). You could easily convince yourself you're driving a track car. The engine note completes the illusion.
The Edmunds one makes an interesting point, that they wish 'it was designed more for regular roads, not race tracks' which I'd never expect to hear about a Lexus--too sporty.
The MotorTrend test is remarkably positive...one of the best Japanese cars ever, an editor comments.
I guess I will have to test drive it someday ....... before I order it
Edmunds
Some Excerpts
Some Excerpts
F Is for Fury
Regardless of what it means to the luxury carmaker (and how it appears to the serious sport-sedan buyer), the 2008 Lexus IS-F is a serious piece of highly engineered hardware indeed. At its heart, the 5.0-liter V8 (2UR-GSE) comes from a stroked version of the 4.6-liter engine (1UR-FSE) found in the luxo-cruising Lexus LS 460. Now that Yamaha (a frequent collaborator with Toyota for engine projects) has had its way with it, an essentially all-new engine pumps out an impressive 416 horsepower at 6,600 rpm with 371 pound-feet of torque available at 5,200 rpm.
The engine's lightweight reciprocating mass (said to be half that of other UR engines) combines with variable valve timing to produce a lofty redline of 6,800 rpm.
When you pour the 5.0-liter V8's power through the highly modified eight-speed automatic transmission (from the LS 460), the 3,780-pound IS-F is good for a 4.8-second time to 60 mph on the way to a quarter-mile in 13.2 seconds at 109 mph, and it's still accelerating hard — very hard.
We admit we might've left a tenth or two on the IS-F's table, however. As much as we feel that Michelin Pilot PS2 tires are like sticky Lucky Charms, the IS-F's 255mm-wide rear contact patches aren't wide enough to duplicate a magically delicious launch.
That said, the roar of the rev-happy V8 is one of the most lust-worthy we've heard, rivaling the thrilling sound of the 4.2-liter V8 in the Audi RS 4, which also sounds like a flat-bottom drag-racing boat powered by a small-block V8 with open headers.
Though if drag racing isn't quite the IS-F's sort of environment, road racing is. Besides the four other racetracks where camouflaged IS-F mules spent much of their time during testing, the car primarily was developed on Toyota's own Fuji International Speedway. A nice thing, if you can afford it.
What this did for the IS-F is readily evident in the car's ability to hold a line in the corners, the linearity and tractability of the engine's power, and the magnificent proficiency of the transmission's shift action in manual mode.
The brakes are also track-worthy. The fixed Brembo six-piston front calipers feature three different piston diameters and clamp 14.2-inch drilled and vented discs, while two-piston rear calipers squeeze 13.6-inch drilled and vented discs in the back. Sixty-to-zero stopping distances tumbled down with each successive stop with a best of 112 feet. We tired before these fade-resistant brakes did.
The IS-F's turn-in is breathtakingly quick, as the car takes a confident and very firm set through corners with pretty stubborn understeer on the car's limit. We measured 0.93g on our skid pad.
Though the steering action is as precise as any rack-and-pinion can deliver, the artificially heavy effort of the two-mode, electric power assist (a 42V system) still cannot communicate as much information about the contact patches of the front tires as other sport sedans we've driven. Even so, the IS-F weaves its way to an exhilarating 70.2-mph slalom run where oversteer becomes the limiting factor. Credit the car's weight distribution of 54 percent front/46 percent rear.
Automatic transmissions are slow-acting, power-sapping, indirect hindrances between an engine and a driver's will, right? Yet the IS-F's eight-speed Sport Direct Shift automatic transmission (AA80E) obliterates this notion with an entirely novel — and we think industry-changing — control system.
When manual mode (shifted via steering-column paddles or the console-mounted gearlever) is selected, upshift times drop from a Lexus IS 350's typical 1.3 seconds (0.7 second to initiate plus 0.6 second to change ratios) to a mere 0.3 second (0.2 second to initiate plus 0.1 second to shift). We also appreciate the perfectly timed tone that reminds you to shift just before you hit the rev limiter in each gear.
The gloriously quick downshifts (with matched revs) sound as if the car has a true sequential gearbox. It's unbelievable. The only other transmission that comes close to such quick, driver-friendly action is the dual-clutch DSG gearbox like the one in an Audi A3, or perhaps the latest $9,000, Formula 1-style automated sequential manual like that in the Ferrari 599 GTB Fiorano.
While the kind of on-track schooling the IS-F has received is generally a good performance-tuning practice that tends to breed more performance-capable vehicles, it doesn't always make for a livable car.
The IS-F short-travel suspension rides taut and firm like a racecar's — all the time. Without driver-adjustable suspension, freeway overpasses that are usually registered by the seat of your pants as a gentle, rolling hop become spine-compressing jolts. Consider yourself warned.
This is an interesting point which was brought up with the IS itself, Consumer Reports has complained that the IS 250/350 ride is too harsh. With the IS-F, Edmunds seems to want a more road-friendly ride while MotorTrend did not complain about it.
Lexus Connoisseur
That same Matador Red IS-F was the same one that was brought up to HIN Nightshift in Pleasanton the next day after that press event:
9-30-07 IS-F Visits HIN in NorCal - Matador Red w/Black Interior
