Lexus Launches 'IS F' in Japan
Lexus Connoisseur
http://www.toyota.co.jp/en/news/07/1004.html
TOKYO, May 17, 2007 — Lexus announced today that it will begin sales in Japan, starting on December 25, of the "IS F"*.
IS F (with options)
IS F (with options)
The IS F is a Lexus "F" premium sports car based on the concept of proposing a new level of performance for Lexus through a refinement of basic performance with the addition of new cruising technology. The vehicle was developed to pursue, to the fullest extent possible, the "joy of driving" — which is one of the fundamental appeals of the automobile — by responding reliably and performing as intended.
Based on the IS series, the IS F boasts a completely new engine and transmission, an exclusive suspension and specially selected aluminum wheels and tires. The vehicle was tested extensively on race circuits in Japan and overseas, including Fuji Speedway, in order to demonstrate its full potential. Detailed attention to the responsiveness of the acceleration, gear shifting, steering and brakes, as well as to the actual experience of quality (such as engine sound and the sensation of acceleration), has created a new type of driving pleasure — not just for the driver but for passengers as well — thus expressing the emotional appeal of the Lexus brand.
* Based on the idea of creating a vehicle that can run on various types of roads, the vehicle was extensively tested on race circuits, including Higashifuji Technical Center and Fuji Speedway. The "F" in the IS F name comes from the "F" in "Fuji Speedway".
Note: Products described in this and in any attached materials are for the Japanese market only.
Monthly Sales Target
40 units
Assembly Plant
Tahara Plant, Toyota Motor Corporation
Manufacturer’s Suggested Retail Prices
(Prices in Hokkaido differ; unit: yen)
Model Engine Powertrain Transmission Price (including
consumption tax)*
IS F 2UR-GSE
5.0-liter V8 Front-engine,
rear-wheel drive 8-Speed
Sport Direct Shift 7,660,000
* Excluding recycling fees
Vehicle Outline
1. Performance that Can Maximize Driving Pleasure
* The newly developed 5.0-liter V8 engine is a D-4S (direct injection four-stroke gasoline engine, superior version) that combines both port and direct fuel injection. Advanced technologies, including electric motor-driven VVT-iE (Variable Valve Timing-intelligent system by Electric motor) on the intake side of the Dual VVT-i (Dual Variable Valve Timing-intelligent system), maximize the performance of the engine. This naturally aspirated engine provides a feeling of linear acceleration, high acceleration response and powerful, enjoyable acceleration even at high engine speeds.
* By adopting the dual-intake system, the IS F provides smooth and even torque at low or medium engine speeds and high torque with both air inlets open at high engine speeds. In addition, the engine sound goes through three transitions in line with rpm to offer true sports car stimulation.
Engine Specifications
Model 2UR-GSE
Type V8 DOHC
Displacement [cc] 4,968
Bore x stroke [mm] 94.0 x 89.5
Fuel supply system D-4S (direct fuel injection + port fuel injection)
Fuel type Premium unleaded gasoline
Compression ratio 11.8:1
Maximum output [kW (PS) / rpm] 311 (423) / 6,600
Maximum torque [N-m (kg-m) / rpm] 505 (51.5) / 5,200
Exhaust emissions levels compared to the Japanese 2005 standards1 75% lower
Fuel efficiency in the 10-15 Japanese test cycle2 [km/l] 8.2
1. Specified under the Japanese Ministry of Land, Infrastructure and Transport's (MLIT) Approval System for Low-emission Vehicles
2. Outlined by MLIT
* The 8-Speed Sport Direct Shift transmission is based on the eight-speed automatic transmission used on the LS460 series, with electronic control technology that provides the benefits of both the smooth shifting of an automatic transmission for comfortable driving and a full-scale, sporty manual transmission that does not need a clutch — which is without precedent anywhere in the world* for an eight-speed transmission. The two-pedal sports transmission also offers new value and perfectly suits a premium sports car. In addition to smooth shifting when the lever is in "D", the torque converter allows smooth and powerful acceleration when starting up in first-gear by putting the lever in "M". In gears two through eight, the direct connection between the engine and the transmission results in direct acceleration response. While achieving one of the fastest gear-change responses in the world, the transmission also has a blipping (revving) control feature that—in the fashion of the heel and toe technique used by race drivers—automatically increases engine rotation speed during downshifts to avoid downshift jolts. In addition, the IS F also features a special paddle shifter that can be operated without the need to remove one’s hand from the steering wheel.
* The springs, shock absorbers, stabilizers and other parts have been optimally tuned for an exclusive suspension that is based on the IS series suspension, which provides both outstanding stability and a feeling of agility. The vehicle offers excellent cruising performance that is capable of handling race circuits.
* In addition to 19-inch forged aluminum wheels that are both strong and light, the IS F uses large-diameter, wide 225/40R19 tires at the front and 255/35R19 tires at the rear for superior gripping performance, excellent handling and cruising stability.
* The IS F has high-performance brakes that can withstand even extreme braking on race circuits.
* The VDIM (Vehicle Dynamics Integrated Management) system stabilizes the vehicle by coordinating control and achieving an optimum balance between drive power, steering and braking, thus allowing high preventive safety. The IS F's VDIM has a "sports" mode that ensures safety while maximizing vehicle performance.
* As of September 2007, according to a TMC survey
2. Interior and Exterior Designs and Exclusive Equipment Appeal to a Sports Car Mindset
* The hood, grille, front fenders and front and rear bumpers, rocker panel molding, rear spoiler and other elements were designed exclusively for the IS F based on the Lexus design philosophy "L-finesse"*. The exterior styling has a dynamic yet simple form that expresses the vehicle's cruising performance and functionality.
* The sharply contrasted interior uses the colors black and white with blue accents that are exquisitely placed. The center console and armrests feature special ornamentation.
* The gauges have an exclusive metal ring achieved through cutting work. The gauge needles feature blue LEDs and a speedometer that goes up to 300km/h. (Vehicles with domestic specifications have a function to limit speeds that activates at 180km/h.)
* The four sports-car-style seats emphasize a degree of holding power that can withstand cruising on race circuits.
* The 14-speaker Mark Levinson® premium surround-sound audio system has been tuned specifically for the IS F (optional on all vehicles in the series).
*Created by combining "leading-edge" and "finesse" design concepts
3. Class-leading Safety and Environmental Performance*
* The Pre-crash Safety System, which uses millimeter-wave radar, warns drivers that a front-end collision is imminent and works to reduce injury if an accident occurs (optional on all vehicles in the series).
* Along with an impact-absorbing body and strong cabin, the IS F achieves further contributions to class-leading safety performance through dual-stage SRS (Supplemental Restraint System) airbags for the driver and front passenger seat (SRS twin-chamber airbag for the front passenger seat); SRS knee airbags for the driver and front passenger seat; SRS side airbags for the driver and front passenger seat; and SRS curtain shield airbags for both front and rear seats.
* Efforts were made to improve fuel efficiency in order to reduce CO2 emissions. The vehicle boasts a fuel efficiency of 8.2km/l in the 10-15 test cycle outlined by the Japanese Ministry of Land, Infrastructure and Transport (MLIT) with CO2 emissions under the test cycle just 283g/km. Both NOx (nitrogen oxides) and NMHC (non-methane hydrocarbons) have also been reduced, achieving emissions levels 75% lower than the 2005 standards under the MLIT's Approval System for Low-emission Vehicles.
* The IS F benefits from Eco-VAS (Eco-Vehicle Assessment System) — Toyota's original comprehensive environmental impact assessment system — achieving overall reduction of environmental impact throughout the vehicle's entire lifecycle. Environmental targets were set in the initial vehicle development stage and a life cycle assessment was carried out to achieve a reduction of air contaminants and CO2, etc., throughout all stages of the vehicle's life from production and use to disposal.
* In addition to using highly recyclable materials, greater attention has been paid to the environment by, among other means, reducing the use of substances of concern such as lead, mercury, cadmium and hexavalent chromium, achieving the Japanese automobile industry's voluntary goals of eliminating the use of these substances.
*Compared to vehicles of similar engine displacement
IS F (with options)
IS F (with options)
40 units
Assembly Plant
consumption tax)*
IS F 2UR-GSE
Vehicle Outline
Model 2UR-GSE
Type V8 DOHC
2. Outlined by MLIT
Lexus Connoisseur
It just dawned on me....the release was set today 10/4/07, but notice the actual print reads May 17, 2007? Hmmmmmmm.
Probably keeping that under wraps...
Yeah and I prefer using IS-F to IS F...that in text may get confusing.
Tech Info Resource
Sad day. Looks like the IS-F won't be on my hit list. It needed 430 minimum with the 100 lb weight add for me to even think about it. I guess I'll drown my sorrows in a single turbo for the Supra and laugh as the IS-F shrinks in the mirror.
I agree I was hoping for around 435, but two extra gears can do a hell of a lot.
I not expecting anymore than 417hp now, but I think we may be surprised at what those 417 horses can do.
The only hope (if you can call it that) is if the engine is in-fact detuned or that Lexus is lowballing the engine numbers on purpose. It also will indeed be interesting at the ultimate performance of the IS-F. If it can keep up with the competition in a straight line and on the track, then it won't be so bad.
Gearing can play a considerable role in a cars overall performance, wait till some real work testing occurs before jumping on the ,"I wanted 700hp" bandwagon. I would rather have a well geared 8 speed with 417hp vs a 5 speed car with 450hp. Of course it all depends on the ratios.
flipside909
09-18-07 09:13 PM
