Anyone compare their coilover set up to the 2012 oem suspension changes?
Old 04-16-14, 11:38 PM
sr20bet
sr20bet's Avatar
Default Anyone compare their coilover set up to the 2012 oem suspension changes?
wanted to know if anyone has compared their coilover suspension to the oem suspension changes in the 2012?
what are the pros and cons you qualitatively observed or noticed?
if you had a pre 12 car, would you opt for the changes in the oem 12 suspension, go for the coilovers or not change anything wrt to your suspension?
which was better for day to day usages (non-track)
thanks in advance for any feedback.
Old 04-17-14, 12:03 AM
G9N
G9N's Avatar
Very interested to the feedback.
Old 04-17-14, 05:04 AM
ULTSISF
ULTSISF's Avatar
U made 3 different threads w questions that already been asked before. Expect to get flamed lol
Old 04-17-14, 08:46 AM
shahir18
shahir18's Avatar
searching would go a long way, I am able to even google search your questions and get a few threads from clublexus as results in which can help you with the answers!
Old 04-17-14, 08:49 AM
sr20bet
sr20bet's Avatar
It's my first thread on this forum and a search was performed and relative threads were read. None answer my question.
Do the first two responders have anything useful to add?
Old 04-17-14, 08:51 AM
sr20bet
sr20bet's Avatar
Where are the 3 identical threads? Please let me know so I can correct myself? Thanks in advance for finding the three identical threads.
Old 04-17-14, 10:42 AM
ULTSISF
ULTSISF's Avatar
look at the pic n find ur screenname. You could had asked all those questions with just 1 thread. No need to clogged up the page with stuff that has already been discussed.
Attached Thumbnails Anyone compare their coilover set up to the 2012 oem suspension changes?-image.jpg
Old 04-17-14, 11:02 AM
shahir18
shahir18's Avatar
Suspension Answer:
2012 did have an upgraded suspension, softer ride then all the years before... Getting Coilover would be the best option to get depending on the specs of the spring rates - BC Coilover w/Swift Springs are the most common and the best all around choice to get.
Steering ECU:
Yes you can upgrade the 08-10 steering ECU with the 2011+
I have done the search for you...
https://www.clublexus.com/forums/is-...011-model.html
https://www.clublexus.com/forums/is-...it-2010-f.html
VDIM / ECU:
No, part numbers are not the same. Each year had a different ecu part number and serial number
Old 04-17-14, 01:26 PM
sr20bet
sr20bet's Avatar
Originally Posted by "that boy"
Suspension Answer:
Steering ECU:
VDIM / ECU:
Thanks. I wonder if the vdim is only difference on the programming chip within the ecu. for a logical stand point, lexus / toyota wouldn't make a whole new ecu, they would just change the tolerances and parameters.
Old 04-17-14, 03:47 PM
jat0223
jat0223's Avatar
The suspension was upgraded in 2011. It provided a better ride quality and improved lap times by a decent amount. Then it was upgraded again in 2013.
Old 04-17-14, 03:50 PM
caymandive
11 Second Club
caymandive's Avatar
Keep on topic guys and if you have nothing beneficial to write then say nothing.
Old 04-17-14, 04:22 PM
sr20bet
sr20bet's Avatar
It would be great if eventually the part numbers for the pre-11, 11-12, and post-13 suspension changes were listed.
Old 04-17-14, 11:43 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,849 Likes on 2,334 Posts
Why? Target what you want, buy it, install it, be happy. It's not rocket science. Lexus has enough trouble getting automotive journalists basic information about the year to year changes, and they get it wrong more often than not.
If you really want part numbers, there are any number of sites where you can catalog the differences over the years. It still won't tell you what was actually changed or why.
Old 04-18-14, 08:23 AM
scamsel
scamsel's Avatar
believe there were suspension changes in 2012 as well actually:
front and rear shock absorber assembly
front and rear coil springs
and parts located around the shocks and springs.
shape of rear spring bumper, "to ensure a driving comfort" haha
lexusondubs
11-16-14 08:00 PM
Dymelos
IS F (2008-2014)
15
09-03-12 09:32 PM
luxaro
05-03-11 07:19 AM
mrsardar
Suspension and Brakes
01-09-08 08:08 AM
Quick Reply: Anyone compare their coilover set up to the 2012 oem suspension changes?
