Question about painting calipers
Old 03-01-14, 11:18 AM
Mydogbella
Mydogbella's Avatar
Default Question about painting calipers
Hey guys...I am going to paint the calipers without removing them...I will tape off everything..my question is this...after they are painted...do I place the brembo stickers on..then spray the clear coat?
Also how many coats of vht paint and clear coat do you guys recommend?
Old 03-01-14, 11:25 AM
ISFalex
ISFalex's Avatar
Originally Posted by Mydogbella
Hey guys...I am going to paint the calipers without removing them...I will tape off everything..my question is this...after they are painted...do I place the brembo stickers on..then spray the clear coat? Also how many coats of vht paint and clear coat do you guys recommend?
I was wondering the same thing
Old 03-01-14, 02:04 PM
digger08
digger08's Avatar
IMO.....Typically 3 coats of spray will be fine - as you will have dry time in between coats (20 minutes)
...let it cure for at least 24 hours, then the stickers
...some light coats of high temp clear is all that is needed (as many applications as you want)
.....but in very light stages or coats each time (particularly on that first coat over the stickers)
If you go too heavy on the first one the stickers may curl as the vinyl reacts to the overcoat.
Digger08
Old 03-01-14, 02:26 PM
Mydogbella
Mydogbella's Avatar
Thank you.
Old 03-01-14, 02:40 PM
edgeucated
edgeucated's Avatar
3 coats of paint, giving time to dry in between and then apply the stickers. Next, I did 2 clear coats.
Old 03-01-14, 02:48 PM
Mydogbella
Mydogbella's Avatar
Thanks guy's for the help.
Old 03-02-14, 10:56 AM
Just F Me
Just F Me's Avatar
which stickers are you guys buying online?
Old 03-02-14, 12:05 PM
Mydogbella
Mydogbella's Avatar
I purchased mine from eBay.
Old 03-02-14, 09:25 PM
Murph145
Murph145's Avatar
I bought my paint from automotivetouchup.com best aerosol cans ever!!! you can pick any color paint you want and then the clear sprays on so nice!
I did about 5-6 coats of color with 15 minutes in between coats.... really depends on outside temp it was like 80 here so coats dried fast. Put on my BREMBO decals and did about 5- 6 coats of the clear looks perfect and no problems!!!
good luck
Old 03-02-14, 10:27 PM
IceIridium
IceIridium's Avatar
What kind of prepping is involved before painting? Sanding? Brake cleaner?
Old 03-02-14, 10:28 PM
fasttexasz
fasttexasz's Avatar
good luck
Is it a high temp paint and clear?
Old 03-02-14, 10:50 PM
CalitriSC
CalitriSC's Avatar
No clear coat over my decals. Make them much easier to replace if needed and will never bubble
Trav7414
05-12-09 12:55 PM
GUNRU-GS4
Suspension and Brakes
24
07-24-08 02:28 PM
dk0515
Wheels, Tires & Brakes Forum
22
09-18-07 08:14 PM
3rdelement
06-30-05 12:14 PM
VEGASRX330
RX - 1st Gen (1999-2003)
06-09-04 07:41 AM
Quick Reply: Question about painting calipers
