Failed Visual Inspection CA Smog
Old 02-27-14, 04:09 PM
dh784123
dh784123's Avatar
Default Failed Visual Inspection CA Smog
Hey Guys,
Took the car in for Smog Check today, the tech said he I failed "Visual Inspection" as one of the Vaccum Hoses was disconnected an zip-tied away. I'm the 2nd owner of the car, and the previous owner had installed a JoeZ intake.
I have attached some photos of the where the "disconnected/tied-off" vacuum hose is. Any reason why this hose should or shouldnt be connected?
Based on the EVAP diagram it looks like its the hose where the Vacuum Switching Valve goes into the Actuator...
Should i just take off the zip-tie and reconnect it?
BTW, the car runs great with no issues whatsoever, no check engine light or VSC lights.
Old 02-27-14, 04:22 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,848 Likes on 2,333 Posts
I have no idea why someone would do that. Just connect the hose and enjoy the new sound of the intake flap opening.
Old 02-27-14, 04:26 PM
jdmSW20
jdmSW20's Avatar
i wonder why on earth the previous owner wouldve done that in the first place?
Old 02-27-14, 04:30 PM
H60Driver
H60Driver's Avatar
https://www.clublexus.com/forums/sho...d.php?t=383384
Old 02-27-14, 04:38 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Yes, but it was proved to lose power, not gain. Doing this is silly.
Old 02-27-14, 05:14 PM
H60Driver
H60Driver's Avatar
^^agreed. Just showing the OP what and why it was done.
Old 02-27-14, 06:33 PM
LionelHutz
LionelHutz's Avatar
You got popped for a vacuum hose but not an aftermarket intake???? Weird inspector.
Old 02-27-14, 07:34 PM
vmatheboss
vmatheboss's Avatar
I just passed mine here is san Francisco.I had removed my red hps intake tubing to avoid extra "looks"from the inspector. He asked me about my exhaust I told him it's stock (I have borla catback) lol.
Old 02-27-14, 07:49 PM
Raybean
Raybean's Avatar
Should of just slip him a 20
Old 02-27-14, 07:58 PM
dh784123
dh784123's Avatar
Thanks guys! Just reconnected it!
Back to the smog station tomorrow for a "re-test"
Old 02-28-14, 07:54 AM
MisterSkiz
MisterSkiz's Avatar
Wow, another reason I could never live in California...stinks because the weather is nice there
Old 02-28-14, 08:38 PM
zazzn
zazzn's Avatar
lol these inspectors are ****ing retarded, they have no idea what the vac line does but will fail it anyways.
Anyways, yes, you can put it back on because apparently someone that tested it at the track actually went faster with it ON than OFF.
Old 03-01-14, 01:18 AM
bnizzle87
bnizzle87's Avatar
Hopefully the OP got the pass the second time around. A silly little zip tie caused the inspection fail, while a bright blue intake didn't. My shop guy knew about my Joe Z itake and I had the stock intake with me in case he needed to go by the book. CA and its smog regulations both visual and mechanical are the only reason why I still keep my OE parts. Friends from the BMW and MB crowd are frantically scouring the net for stock parts to swap just because they failed either the visual or the smog run itself.
Old 03-01-14, 09:56 AM
CCLSVTF
CCLSVTF's Avatar
Yeah, but everything else sucks.... LOL, born and raised in SoCal and I want to defect to AZ......
Stu
08-30-17 04:35 AM
wilsonwho
05-26-16 08:24 PM
LexBrett
12-19-14 06:14 PM
GS4VIPbOSS
Performance & Maintenance
07-05-08 02:54 PM
huerdo623
08-10-07 11:36 AM
Quick Reply: Failed Visual Inspection CA Smog
