Header install and now first code
Old 05-23-13, 08:55 AM
PhiDeltBee
PhiDeltBee's Avatar
Originally Posted by Super6
Glad to hear you no longer have any codes! In regards to doubling up gaskets: Was this easy to do after the fact and where can I get an extra gasket?
Very simple. Just unbolted the exhaust from the headers, slid them in, and rebolted. Got the 2 gaskets from PPE's website for $16.
Old 05-23-13, 10:32 AM
CarbonISF
CarbonISF's Avatar
Originally Posted by PhiDeltBee
Wanted to update this thread. On May 11th (after my 3rd code), I decided to double up the PPE gaskets where the headers meet the Joe Z exhaust. I did this even though we never found any leaks using soapy water. I also took out both O2 sensors and swapped sides. So far, so good. No more codes. The strange thing was, I was throwing the code the same way all 3 times. Driving down the highway for 10 minutes or so, and then down shifting when hitting the offramp. Every time the code went was the 4-3 downshift. Strange, but I'm going to knock on wood and hope I fixed it.
Mine are doing the same thing, and it almost always happens on the same off-ramp, in the same condition you described. Always P0159 though and nothing else.
Weird we both have the same symptoms... I keep a cheap code scanner in the car in case I need to clear it, but it only happens every 10k or so.
Old 05-27-13, 09:27 AM
PhiDeltBee
PhiDeltBee's Avatar
Welp, it happened again last night. Same situation...Driving down the highway for 10 minutes, hit the off ramp and when I downshifted from 3 to 2...bam....code. Went to Autozone this morning and got a P0139 code which I believe is now the driver side O2 (the same sensor as before that I swapped sides). So essentially it went from bank 1 to bank 2. I'm going to rule it as a faulty sensor at this point and replace. Wash, rinse, repeat.
eaglclon12
IS F (2008-2014)
13
08-25-17 08:04 PM
Lmood
IS F (2008-2014)
12-18-13 06:54 PM
Hoac
Performance
03-11-12 01:31 PM
AMGWNAB
Performance
03-08-12 07:56 PM
GSE20MT
CL of Hawaii
02-07-09 07:58 PM
Quick Reply: Header install and now first code
