Installed my Wald "Style" spoiler today...
Old 02-08-15, 09:08 PM
  #61
Sylvan
Sylvan's Avatar
Which "Waldo style" did you get? I got a SFP from car king and the paint match sucks it's too white for others considering buying it. I also had the wavey body work digger posted in the first post but it's hard to notice the waves once it's installed
Old 02-09-15, 05:06 AM
  #62
Lexusboy4
Lexusboy4's Avatar
Default Removing oem spoiler
How did get those 7 tabs out if the spoiler, I'm don't if I just need to pull hard or what.. Yours is sick by the way.. Good job
Old 02-09-15, 09:44 AM
  #63
ISF4life
ISF4life's Avatar
u got to loosen the liner underneath the trunk and take out those bolts and then its will come off.
Old 02-18-15, 09:21 AM
  #64
vietzboi87
vietzboi87's Avatar
Talking
Originally Posted by digger08
The diffuser is also held on by those two rear deflectors (from the Highlander - should you lose one)...so you will need to drill, they're length is very short and they just barely fit through the bumper - so you will need to drill 2 small holes through your bumper - they are bolts with nuts. There is also two small screws for the bottom of the diffuser as well. This is the main reason why you will need to remove the bumper completely to install this properly.
You can see the hole here, with the reflectors removed.
There is also two small screws for the bottom of the diffuser on each end that go through the bumper as well.
I used Permatex Ultra Gray High Rigid/ Torque just along the top - where the gaps were.
The rest of the diffuser, I use 3M foam tape.
The RTV sealant has not shrunk, peeled or separated at all for the last year/ including two track days.
Digger08
Hey, you said the reflectors can be purchased by the highlander? Can you clarify where that is? Thanks
Old 02-18-15, 12:48 PM
  #65
Meraki Autoworks
Your #1 Lexus Vendor
Meraki Autoworks's Avatar
pretty much he means that the red circles are from a toyota higlander or a toyota with those reflectors, I think it was 2.25" in diameter.
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Old 02-18-15, 08:55 PM
  #66
digger08
digger08's Avatar
Here's the parts as included by Wald with the rear diffuser...2010 Toyota Highlander rear bumper reflectors.
Digger08
Old 02-19-15, 12:40 PM
  #67
iH8RICERZ
iH8RICERZ's Avatar
This is the one I bought... yes, right out of the box, the white is a lot brighter. Once you let it get exposed to the sun and give it a little bit of time, the color darkens a little bit and its probably a 80% match. As for the wavey body, you could almost feel it if you run your fingers across it. Almost wish I would've went with a CF or a PU one and have it molded/painted. Oh well, funds were tight at the time
Old 02-19-15, 12:45 PM
  #68
Meraki Autoworks
Digger08
any issues with the ISS tips and the wald diffuser? I have the QES system, don't know if its that much bigger.
__________________
Orange County, CA
Old 02-19-15, 01:08 PM
  #69
Jump2man3
Jump2man3's Avatar
Looks freaking awesome love the lip styling for the rear of the isf
Old 02-19-15, 08:20 PM
  #70
digger08
digger08's Avatar
No not really.....slight rub but very minor (to be expected as exhausts move)
Digger08
Old 02-20-15, 12:42 AM
  #71
Meraki Autoworks
Digger08
thank you sir.
__________________
Orange County, CA
Old 02-22-15, 12:00 AM
  #72
ISF94
ISF94's Avatar
Where did u get that wald replica the fitment is bang on
Old 02-22-15, 01:40 AM
  #73
Meraki Autoworks
^ I got mine from car king I think.. an ebay seller.
__________________
Orange County, CA
Old 02-22-15, 02:22 PM
  #74
Soopastank
Soopastank's Avatar
Cool - thanks for posting
Old 12-07-15, 12:17 PM
  #75
STLblueF
STLblueF's Avatar
So I have placed an order for a wald rear diffuser but I had a couple questions:
The red reflectors - these aren't actual lights are they? I've seen some at least one person who wired them up to their parking lights, but I assume that was done with some aftermarket parts. If they aren't lights, couldn't I snap off the screw and just use double sided tape to secure the reflectors to the diffuser, and I wouldn't need to drill two holes in the middle of the bumper?
I'm planning to use double sided tape and the screws underneath, but I don't see why I would want to drill into the bumper unless these actually light up. The replica wald spoiler is not held on with anything other than tape so I am not sure why the diffuser would have to require anything more. I'd like to be able to remove the diffuser in the event that I sell the car and not have holes in the middle of the bumper.
Quick Reply: Installed my Wald "Style" spoiler today...
