Monsters of Grip
Old 08-04-12, 04:32 PM
  #31
flowrider
flowrider's Avatar
Received 1,815 Likes on 1,281 Posts
Originally Posted by Gymkata
I feel for you. I have experienced this on previous vehicles.
This is why tirerack's detailed specs are nice. You can see what they have listed for section & tread width, which can vary quite a lot. For example, a 275mm and a 295mm tire should only be 20mm difference in width theoretically...in reality though (according to tirerack with Michelin PSS tires) the 295/30ZR19 tire has a 302mm section width and a 292mm tread width. The 275/30ZR19 tire has a 277mm section width with a 259mm tread width. That is a 25mm wider section width and a 33mm wider tread width! The 305/30ZR19 is even wider still at a listed 312mm section width and a 307mm tread width...that means if tirerack is right, the tread is actually wider than the section width stated on the tire...just something to consider next time you purchase tires.
What you are saying is true, however, the tire's section width is also affected by the width of the wheel it's mounted on. As a rule of thumb, each .5" in rim width corresponds to .2" change (+/-)in tire cross section. IOW, a tire with a cross section of 295 measures 11.9" according to Tire Rack, when mounted on a 10.5" wheel. This same tire when mounted on a 10.0" wheel would measure 11.7" and 11.5" when mounted on a 9.5" wheel. Hence, my thoughts in my preceding post.
Lou
Old 08-04-12, 07:26 PM
  #32
KJH
KJH's Avatar
Originally Posted by weswork
I REALLY wanted to experience the Mich SSs on my car but to no avail. I have learned the hard way that not all tire sizes (dimensions) are created equal and there can be significant varition. I recently picked up some new wheels for my car (BC Racing - Thanks Figs) in 9x19 front and 10.5x19 rr in offsets that should work with no mods. This combo has worked on other cars with other tires well. The 295/30 are BIG. We put these on my car and even with fender rolling, rasing the car up (KWs) and some mild camber adjustment it was still rubbing sporadically but enough to not be good for a daily driver.
I know there are others out there that have different wheels with different offsets that have run a 305 in the super sports (KJH on the forums/Ken we need to talk) but I thought I would put this out there for those looking into tires.
Also thought I would put in an early plug for some Mich SS that are up for sale with no miles on them other than the test fit/drive. Shoot me a pm if interested. Will probably try to put them on Ebay later today. 255/35-19 and 295/30-19.
http://www.gmpperformance.com/index....3#!prettyPhoto
Westley
Wes,
Check your email.
'Tis true. The Michelin PSSs are BIG tires with AGGRESSIVE rim protectors. They place a premium on absolutely correct offsets. I have 19 x 9.5s and 19 x 11s on 265/35s and 305/30s, respectively. Coupled with the concavity of my wheels, it was a LOT of work to get the fitments just so, given my preferred ride height. I had my tires about 6-months earlier than my wheels. They are GREAT tires and I would not want to give them up unless I absolutely had to.
Old 08-04-12, 11:15 PM
  #33
Gymkata
Gymkata's Avatar
Lou
Yeah, I was going to put a little blurb in my comment about this. I got so long winded in my post that by the end I forgot
Old 08-04-12, 11:19 PM
  #34
Gymkata
Gymkata's Avatar
Did you have to do anything special to fit the 265/35ZR19 in front?
Old 08-04-12, 11:43 PM
  #35
KJH
KJH's Avatar
No, nothing special at all. Just mount, balance, corner weight and align the car. I'm lowered on HKS Hipermax M1 coilovers.
Old 08-05-12, 03:50 AM
  #36
mikenbn
mikenbn's Avatar
Great read, the PSS are a very chubby tire. Check out this link, it has pics which show you exactly how wide these tires are compared with other brands
Nitto 315 vs Michelin PSS 295
Old 08-05-12, 05:32 AM
  #37
Gymkata
Gymkata's Avatar
What offsets do you have? I would love to fit a 265mm tire on the front.
Old 06-23-14, 02:55 PM
  #38
Gymkata
Gymkata's Avatar
It looks like we have another great tire option.
http://blog.tirerack.com/blog/bens-b...e-f86a3eb73c7a
The Yokohama Advan Sport V105 is a little pricy, but seems to perform very well and comes in good plus sizes for our cars. Funny enough though, it isn't available in 245/35R19 or 275/30R19. It does come in 255/35R19, 265/35R19, 285/30R19, & 295/30R19 though.
Old 06-24-14, 07:06 AM
  #39
melbitoast
melbitoast's Avatar
Nice find! Thanks!
I'm running a 245/275 set up right now. What would be my options for this tire if I chose to continue a wider, staggered set up?
Old 06-24-14, 08:37 AM
  #40
Gymkata
Gymkata's Avatar
Originally Posted by melbitoast
Nice find! Thanks!
It depends on what width wheels you have and if they have conservative enough offsets to fit wider tires. If you had the 2012+ stock ISF wheels for example (19x8.5 +45 & 19x9.5 +52 ...I think), then 255/35R19 front and 285/30R19 rear would be perfect. If you had a 19x10.0/10.5/11.0 +55to+60, then you could run 295/30R19s in the rear.
Old 06-24-14, 10:04 AM
  #41
flowrider
flowrider's Avatar
^^^^I'm running the 245/35, 285/30 combo (Bridgestone S-04 PPs) on my stock width 08 wheels with no issues. Great Handling
https://www.clublexus.com/forums/is-...-position.html
Loi
Old 06-24-14, 10:15 AM
  #42
melbitoast
melbitoast's Avatar
Stock '08 wheels. What options does that leave me with?
Spam89
RC F (2015-present)
11-28-20 11:59 AM
nomz09
RC - 1st Gen (2015-present)
07-25-17 09:04 PM
Supraman16
IS F (2008-2014)
17
12-02-09 12:37 PM
RA40
Wheels, Tires & Brakes Forum
11-13-05 12:54 PM
Quick Reply: Monsters of Grip
