Apexi Throttle Control installed: i love it :D
Old 03-29-12, 08:39 PM
meade916
meade916's Avatar
Default Apexi Throttle Control installed: i love it :D
yes, i know, it doesnt make the car faster...it does make it really responsive. To me it feels great, i love it I stay on red mode. Also, next to a 100 shot of nitrous, it really gets down This is the easiest mod to install, took about 10 minutes tops.
a shot of her at the Autorama last month
I got it at horsepowerfreaks.com - if you do decide to get one, dont forget to order the harness!!
Old 03-29-12, 09:07 PM
RCB
RCB's Avatar
My car has the Blitz and I like it.
I really love they way that Apexi unit installs in an existing cut out! Super clean!!
Enjoy
Old 03-29-12, 10:20 PM
RX7 RAGE
RX7 RAGE's Avatar
nice and clean install
Old 03-30-12, 12:06 AM
boostftw
boostftw's Avatar
def a cool gadget, ill have to order one of these! did you also order the reserve module too? Anyway thanks for sharing.
Old 03-30-12, 07:17 AM
meade916
meade916's Avatar
whats a reserve module?
Old 03-30-12, 09:04 AM
Nate008
Nate008's Avatar
^ He meant reverse module
Old 03-30-12, 09:09 AM
boostftw
boostftw's Avatar
oops, thanks for the correction
Old 03-30-12, 09:48 AM
RCB
RCB's Avatar
Correct me if I'm wrong but I know that using any other mod other then stock in reverse can cause damage. I would guess that on the Apexi throttle controller you need to add an additional module that reverts the setting back to stock when you shift to reverse.
Old 03-30-12, 09:49 AM
meade916
meade916's Avatar
it has a reverse wire on it which i did not hook up. I didn't see a need since i actually know how to drive. Besides, when i drive in reverse, its typically right after i started the car (obviously) and the unit does not activate until you actually turn it on. In other words, its not on anyway i dont need something to turn it off when i put it in reverse.
I did put it in "red" mode just to see how it was to back up with it like that. Its not any more dangerous then it being off because when i back out of a parking spot, i usually dont put my foot to the floor anyway. Actually, unless you are a maniac, you dont need to push the gas very much, if at all when backing up so i dont see a problem with not hooking that wire up.
Old 03-30-12, 09:57 AM
mugenh22a4
mugenh22a4's Avatar
Where does the controller or harness plug into?
Old 03-30-12, 04:10 PM
RCB
RCB's Avatar
To the APS....throttle pedal.
Old 03-31-12, 01:19 AM
vrmRollLex
vrmRollLex's Avatar
so in order to get to say, Hi-Throttle mode, every time you start the car you have to press that button 7 times? or how does it work?
Old 03-31-12, 06:59 AM
meade916
meade916's Avatar
nahhh just hit the button once and it goes to your last setting
Old 03-31-12, 10:49 AM
Super6
Super6's Avatar
Looks great. I had something like this (sprintbooster)on my previous car (Benz c350) and it made a world of difference. Glad you are enjoying it.
Old 03-31-12, 06:02 PM
LexyISF
LexyISF's Avatar
Originally Posted by meade916
off topic, but I want that Cuda!!!
Quick Reply: Apexi Throttle Control installed: i love it :D
