Joe Z Intake Pipe - Supplied Worm Hose Clamps Size for T-bolt Hose Clamp Substitute??
Old 12-21-11, 05:59 PM
Kyle4207
Kyle4207's Avatar
Default Joe Z Intake Pipe - Supplied Worm Hose Clamps Size for T-bolt Hose Clamp Substitute??
Does anyone (or Joe Z specifically) know what the exact size of the 4 supplied worm hose clamps that come with the Joe Z intake? I am looking to use T-bolt hose clamps instead and I haven't received my intake yet.
Currently the T-bolt hose clamps that I have found that are available are the following:
2.00" (51mm)
2.25" (57mm)
2.50" (64mm)
2.75" (70mm)
3.00" (76mm)
3.25" (83mm)
3.375" (86mm)
3.50" (89mm)
4.00" (102mm)
Regards,
Kyle
Attached Thumbnails Joe Z Intake Pipe - Supplied Worm Hose Clamps Size for T-bolt Hose Clamp Substitute??-joez_intake_01s.jpg   Joe Z Intake Pipe - Supplied Worm Hose Clamps Size for T-bolt Hose Clamp Substitute??-joez_intake_02s.jpg
Old 12-21-11, 06:05 PM
SeanGTS
SeanGTS's Avatar
The intake pipe will never seen anything above a vacuum, there is no point to this you know?
Old 12-21-11, 06:09 PM
Kyle4207
Kyle4207's Avatar
SeanGTS, thanks and yes I know that the intake pipe will only see a vacuum and no positive pressure. The reason I want to use T-bolt hose clamps is purely aesthetic. I hate how cheap the worm clamps look.
Thanks!
Kyle
Old 12-21-11, 06:24 PM
fasttexasz
fasttexasz's Avatar
The clamps it comes with says 84mm-100mm on them
Old 12-22-11, 03:41 PM
Joe Z
Joe Z's Avatar
Received 1,058 Likes on 586 Posts
Lightbulb
Thanks!
Kyle
Cheap...
They are slighty better than the OEM ones...
And they are indeed Automotive grade stainless steel worm clamps..
~ Joe Z
Old 12-22-11, 04:47 PM
DCoolBeans
DCoolBeans's Avatar
Your intake is never gonna come loose if you get springs on em!!!
Old 12-22-11, 10:01 PM
Kyle4207
Kyle4207's Avatar
@ fasttexasz - Thanks for the sizing
@ Joe Z - Sorry, "cheap" as in aesthetics. I just prefer the clean look of the t-bolts. I'm sure yours are very high quality. So if fasttexasz says they are marked for 84-100 mm which of the following would you recommend since you spec'ed the ones that come with the intake?
3.25" (83mm)
3.375" (86mm)
3.50" (89mm)
4.00" (102mm)
@ DCoolBeans - That's funny.
ChazZ
08-08-22 06:27 PM
es5240
11-30-11 12:11 PM
JoeCombs
01-18-11 03:18 PM
heyarms
Performance
09-08-10 11:13 AM
damon
08-28-09 10:42 AM
Quick Reply: Joe Z Intake Pipe - Supplied Worm Hose Clamps Size for T-bolt Hose Clamp Substitute??
