ISF sub issues
Old 12-18-11, 09:20 AM
meade916
meade916's Avatar
honestly, i havent torn my panel off to look at what is in there.....you might get away with leaving the stock stuff up front intact and sending them more power......but how much more power? I dont know.....i know i am ripping all of it out (except the head-unit) when i get started. Good luck bro!!
Old 12-26-11, 11:46 PM
RspSupra
RspSupra's Avatar
I still can't believe the radio in a 70k car is this bad. Did they upgrade it any in the newer models?
Mark
Old 12-27-11, 03:57 AM
2011ISFNY
2011ISFNY's Avatar
Nope - I have a '12 and have similar issues.
Old 12-27-11, 08:28 AM
zapa
zapa's Avatar
The ml system is was underpowered in my opinion. The stock 8in sub is not going to get the job done. I blew the sub once and Lexus replaced it for free. I ended up putting a JL W6 4ohm with 600 watt mono block JL amp in a ported box. It sounds amazing now i would highly recommend the set up.
Old 01-05-12, 08:51 PM
Kingkrs
Kingkrs's Avatar
My 08 system sounded better than the new 2011 that I have now. I am not sure why either. In my 08 I would only bring the vol up to the mid 40 for the loudest it would go before distortion. Now I am well into the 50 with the new ride. I don't get it.
I have some DVD audio discs that sound excellent in the car though.
Old 05-19-13, 01:41 PM
Gearbangin
Gearbangin's Avatar
Where is the stock sub location?
Old 05-19-13, 02:20 PM
vbb
vbb's Avatar
Whoa, what a bump up to the top!
Stock sub is under the rear deck (back windshield).
Like so many others, I thought the lows on the stock ML were a bit weak so I added a single JL 10 powered by a 300W rms Alpine amp in a custom box, and now I have more bass than I need. Gains on the amp all all the way down, bass set to +3, and I typically listen to my sound system on about 27-28. If I put it up to 35 and some hip hop I'm booming!
Old 05-20-13, 06:58 PM
lexsane
lexsane's Avatar
always on 59. I'm superstitious and 60 is bad luck
Old 05-21-13, 04:45 PM
darkoozy
darkoozy's Avatar
I concur...
I have 2012 IS-F and the sub sucks...The sound is so bad, I took the car back to the dealer thinking the sub was blown (works as designed was the response). The ML sound is pure crap. I still cant believe how crappy the bass response is...
I have a 2013 RX350 and the non ML sound system blows it away...sad.
triniexr
07-11-14 10:58 AM
lukeisf
IS F (2008-2014)
27
08-20-11 12:30 AM
daryltrinh
11-18-09 05:26 PM
jtgs400
04-24-08 12:37 PM
sigers98
02-15-08 08:25 AM
Quick Reply: ISF sub issues
