diy on oil change?
Old 10-19-11, 09:16 PM
96817isf
96817isf's Avatar
Question diy on oil change?
does ne one know the link for the diy for the isf oil change i wanna do it my self cause im tired of waitng at lexus for them to play around with my car while thye change my oil..lol or can some one lead me in the right direction on how to do it... i do know how to turn a wrench but i just don't wanna take all day just to change my oil so ne tips would be greatly appriciated. thanks
inked13 (06-01-21)
Old 10-20-11, 02:12 AM
PurduePete
PurduePete's Avatar
1 - https://www.clublexus.com/forums/is-...il-change.html
or
2 - According to RiotGrip: http://www.lexusfforum.com/forums/showthread.php?t=1754
Do-it-yourself oil change on IS-F/What you need to know!
Well, I just finished my first Do-it-yourself oil change on the IS-F, and the grand total was $34.51 + tax for the oil and filter (yes I used dino). as well as two one time purchases for about $70.00 + tax for two essential tools.
Since I have not seen any other discussion about doing this on the IS-F I'll discuss what you need to know if you are going to change your own oil on this vehicle.
1. YOU CAN NOT JACK UP THIS VEHICLE with a standard floor jack, the set jack point is too far for a normal (i.e very good) car jack to reach. If you own a LONG FRAME floor jack with a 5" or lower lift point, you will be OK. The cheapest I saw one was at SEARS for $499.
2. YOU NEED 12,000lb RhinoRamps or the equivalent to get underneath this vehicle. The 8000lb versions are not as wide and likely less safe. If you already own the 8000lb versions you may try, but I bought the wide ones new and they worked great. You can obtain these for $49.99 + tax at AutoZone. They have a 17 degree incline and this was just enough to get adequate clearance under the front bumper.
3. Once underneath the vehicle the oil pan is easy to access and a 14mm socket will do the trick to get the bolt off. Make sure you have an adequate drain pan, remember the IS-F holds almost 10 quarts of oil. The oil will take a good 5 to 7 minutes to fully drain to a dribble.
4. The oil filter housing resides under a panel that is secured with four phillips head screws, it is fairly close to the front bumper. once removed the housing is easily accessible.
5. I highly reccomend the Assenmacher TOY640 filter wrench (between $17 to $24 + S&H) to remove the housing, it is 64mm with 14 flats and I can tell you IT WILL FIT PERFECTLY! You may be able to get it loose with another tool, but this one worked well and is much cheaper than the toyota/lexus OEM part. BE AWARE that another quart of oil will come out when you loosen and remove the filter housing, make sure you have an oil pan ready.
6. As you probably know we have a cartrige style filter I used the wix part# 57310 for $11.51 at my local auto parts store it comes with a replacement gasket for the housing. I don't know the cost of the toyota OEM part, and I'm not sure if a new gasket is included with each one.
7. After lubricating the new gasket and fitting on the filter housing I placed the new filter in the housing and screwed it back in.
8. Then just add your oil, put the oil cap back on and close the hood.
9. Check your owner's manual for the procedure to reset the service reminder, it has been discussed elsewhere, and it does work.
All in all I was happy with the oil change and it went smoothly with minimal mess. I hope this helps other IS-F owners who were contemplating this task. Please feel free to ask any more specific questions.
Old 10-20-11, 12:20 PM
ItsanF
ItsanF's Avatar
Its super easy bud, in fact, in 3k miles when i change mine again, ill try to post pictures for everyone. Its super easy. I would say the hardest part is getting the oil filter housing off (which really isnt hard at all). Just take of the 4 screws under the car that hide the filter housing, twist the housing off, let your oil drain (make sure you have a large oil container as our car holds a grip of oil), replace the filter, put the housing back on, screw the cover plate back on, pour in your oil, PUT THE CAP BACK ON, reset the oil notification on your dash, go drink a beer. easy as 1, 2....whatever...
Old 10-20-11, 02:52 PM
tenspeed
tenspeed's Avatar
I've been using a anti freeze drain pan for oil changes. It holds about five gallons and has a spout that fits into a milk jug.
Sort of like this one - > http://www.ebay.com/itm/Blitz-11845-...#ht_1055wt_856
Old 10-20-11, 04:33 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,842 Likes on 2,330 Posts
I didn't spend any money on Rhino ramps. I bought a 2 x 10 and had it cut into four pieces then screwed them together to make ramps tall enough to put a jack under the car if I need it, or just change the oil and filter if that's all I'm doing.
Old 10-20-11, 09:17 PM
96817isf
96817isf's Avatar
cool thanks everyone..ill take some pics when i do it this weekend if im not to hung over..lol
Old 03-04-15, 07:03 AM
xianxian
xianxian's Avatar
whats the recommended oil weight for the ISF... I called two dealerships and gave me two different answers
0w20
5w30
Old 03-04-15, 07:24 AM
Sean
Sean's Avatar
The car says 5W-30. At least you found a dealership you might want to avoid.
Old 03-04-15, 07:29 AM
TranV
TranV's Avatar
5W-30...stated on the oil cap in the engine bay.
Old 03-04-15, 07:39 AM
RMA
RMA's Avatar
Recommended weight is 5w30
Old 03-04-15, 08:18 AM
xianxian
xianxian's Avatar
LOL sweet.. thanks bros
the 0w20 also wanted 14 dollars a quart...
I asked where the nearest walmart was
Notgrownup
Maintenance
06-22-19 03:10 PM
poorbong
IS F (2008-2014)
06-22-11 06:47 AM
IS350atWOT
IS F (2008-2014)
08-17-10 01:54 PM
Lexinton
GS - 1st Gen (1993-1997)
15
10-11-07 12:39 PM
Quick Reply: diy on oil change?
