Wheel spacers and lowering springs
Old 05-09-10, 04:48 PM
Mac2924
Mac2924's Avatar
Default Wheel spacers and lowering springs
I just purchased a Ultrasonic blue ISF with white/black int. Can anyone help me with wheel spacers and lowering springs.
Old 05-09-10, 05:08 PM
JDKane527
JDKane527's Avatar
There's a few good spacers out there. I use Ichiba V2 spacers that you can get, I'm sure F owners also use this. They're easy to install, you don't need to swap studs. People have also used H&R spacers, but these as well as others you need to swap the studs so it's harder to do yourself or you can get someone else to do it for you. I went with springs and spacers because I liked the OEM look.
Old 05-09-10, 07:08 PM
N54MPower
N54MPower's Avatar
The spacers as mentioned above along with either Eibach or Tein springs are your choices. If you do a search there are a few cars on here with both of these springs.
Old 05-09-10, 09:00 PM
spekterg35
spekterg35's Avatar
What size spacers are people running successfully? Stock size tires or wider? I'm going with spacers and the teins when it is time to put new tires on and am curious in the same thing.
Old 05-09-10, 09:05 PM
N54MPower
N54MPower's Avatar
The USB in the pic on the attached link is lowered on Teins with 15mm spacers all around per the owner (screen name carlosg).
https://www.clublexus.com/forums/is-...-z-clan-2.html
Old 05-10-10, 06:59 PM
IceIridium
IceIridium's Avatar
For 15mm: Which way is better... Ichiba version 1 with longer replacement bolts or Ichiba version 2?
Old 05-10-10, 07:04 PM
agtuning
agtuning's Avatar
Version 2 for sure!!!!
Old 05-10-10, 11:02 PM
N54MPower
N54MPower's Avatar
Technically version 1 is the better way to go, version 2 is the easier route. Easier and better are not the same in this case.
Old 05-11-10, 01:46 AM
IceIridium
IceIridium's Avatar
I mean which way is better for the car, strength and durability-wise. Which would hold up better to road abuse over a long period of time?
Old 05-11-10, 02:07 AM
kevintq
kevintq's Avatar
are there negative effects if you put on spacers in the front and it brings the tires out wider than the rears?
Old 05-11-10, 08:45 AM
N54MPower
N54MPower's Avatar
The right/better way would be to take out the old studs and replace them with longer ones (Version 1).
Old 05-11-10, 09:16 AM
Robs IS250
Robs IS250's Avatar
Nice man, welcome to CL! Where in Florida are you?
I just ordered a set of springs for a friends F, let me know if you would want to jump in on the deal!
Old 05-11-10, 09:27 AM
JDKane527
JDKane527's Avatar
Not really any negative effects besides steering might feel weird and car may look weird, reminds me of the Can-Am Spyder roadster if front is wider than rear
I would be worried about unnecessarily large spacers in the front though because the front suspension takes more impact than the rear when you hit a dip or bump in the road. I have 15mm in front and 20mm in rear and it's been fine so far. Had it on a few months. I have the V2, I installed it myself and it was easy. V1 I would have to have someone install it, and uninstall it if I ever get wheels.
Old 05-11-10, 10:08 AM
Mac2924
Mac2924's Avatar
Rob,
I live in miami.
What brand of springs and how much?
Old 05-11-10, 10:23 AM
Robs IS250
Robs IS250's Avatar
PM incoming!
Quick Reply: Wheel spacers and lowering springs
