diy oil change
Old 02-21-09, 11:25 AM
550fresh
550fresh's Avatar
Default filter wrench
i use a autozone wrench type f part#25404 it works 4 my is350 and is-f.....just attach it to a socket wrench.......look it up on autozone.com less than 10 bucks...u dont need 2 spend 40 bucks...
Old 02-21-09, 11:26 AM
550fresh
550fresh's Avatar
its called a cap wrench part #25404 type f
Old 02-21-09, 05:50 PM
ISFer
ISFer's Avatar
Thanks, 550..
C.
Old 12-07-12, 01:20 PM
allst4r
allst4r's Avatar
will my is350 oil wrench work on the is f?
Old 12-07-12, 01:40 PM
itsmike177
itsmike177's Avatar
Dang, talk about ressurection.....
Yes, if your oil filter cap wrench fit the IS350, it will fit the ISF. 64mm with 14 flats.
Old 12-07-12, 04:08 PM
allst4r
allst4r's Avatar
just got a 2013 is f =)
Old 12-07-12, 04:24 PM
kauaian
kauaian's Avatar
You change the oil?
Old 12-07-12, 10:58 PM
allst4r
allst4r's Avatar
Originally Posted by kauaian
You change the oil?
no not yet.
Old 05-15-13, 01:41 PM
StraySheep
StraySheep's Avatar
Need help on ISF oil filter part verification.
I just ordered 5 engine oil filters from Sewell and the part number on the filter and online is 04152-YZZA4
http://is.sewellparts.com/accessorie...2009/1897.html
My shop said that the ISF engine oil filter is specific to the ISF and is the same part number as the one mentioned above in this thread. 04152-51010
The length of the 04152-51010 filter looks the same as the 04152-YZZA4, but the paper color seems different.
My shop also said this 04152-YZZA4 is for the 5.7L V8 tundra.
Can someone tell me if 04152-YZZA4 & 04152-51010 are interchangeable?
Or is Sewell's site wrong so they sent me the wrong 04152-YZZA4 oil filter.
Thanks.
Old 05-15-13, 02:18 PM
streetx
streetx's Avatar
04152-YZZA4 works fine for the ISF
its what i have in my car right now
Old 05-15-13, 03:44 PM
flowrider
flowrider's Avatar
Received 1,826 Likes on 1,288 Posts
Thanks.
Check out this thread:
https://www.clublexus.com/forums/is-...il-filter.html
BTW, I use the YZZA4
Lou
Old 05-15-13, 07:02 PM
kauaian
kauaian's Avatar
I bought a case from swell and which was listed in the ISF section. When I got it it was the YZZA4
Old 05-15-13, 07:50 PM
Boma
Boma's Avatar
I use the YZZA4 as well and have no problems. As for the differences in color, not exactly sure why. If I recall correctly the YZZA4 is made in Thailand while the 51010 is made in Japan.
Old 05-16-13, 06:30 AM
StraySheep
StraySheep's Avatar
OK, then I will use the YZZA4 next time. Sewell should correct their online catalog since technically, they are providing the wrong engine oil filter.
Both YZZA4 & 51010 are made in Thailand.
My shop ordered the 51010 and the box says made in Thailand. But I have also seen others with 51010 filter that are made in Japan.
The 51010 paper color does look different and on the box specifically say it's for the ISF engine.
Old 05-16-13, 09:40 AM
UCrazyKid
UCrazyKid's Avatar
Quick Reply: diy oil change
