IS C Discussion about the convertible IS C model
IS250C Alignment Specified Ranges
Old 04-08-14, 12:34 PM
PapaCat
PapaCat's Avatar
Default IS250C Alignment Specified Ranges
I had my 2011 IS250C with 18" wheels aligned at two different Lexus dealerships. I notice the "Specified Ranges" are different in 14 categories. For example, the Front/Right Camber lists a range of -1.4º 0.2º at one dealership, but -0.9º 0.6 at the other dealership. Keep in mind, I'm not referring to the "Actual" and "Before" number - just the ranges that Lexus specifies.
Shouldn't both Lexus dealerships be using the same "Specified Ranges?" I'm wondering which one is correct. So, this is a two-part question:
1. Isn't there one set of "Specified Ranges" that all Lexus dealers should be using when they align the same car?
2. Assuming the answer is "yes" does anyone know where I can view the correct specs so I know which dealership is using correct information?
Thanks
Paul
DanielDD
12-30-15 10:27 AM
skhatri
06-28-07 09:48 AM
gobears
06-10-07 11:50 AM
mjdart
IS - 1st Gen (2001-2005)
05-10-03 11:07 PM
scalbert
12-19-02 02:30 PM
Quick Reply: IS250C Alignment Specified Ranges
