IS C Discussion about the convertible IS C model
Seat cooling mod
Old 02-28-14, 12:09 AM
txjeff
txjeff's Avatar
Default Seat cooling mod
Howdy; I mentioned this in an unrelated thread. I'm looking for a way to cool the driver's seat better than the Cool Dial already supplied. On my long 5.5 hour drive per week, by hour 3, the seat, butt area, and lower back simply get hot. Or really warm. Even on full cool, the seat stays overly warm. I hear there is a mod to supply cool air?
If I can't find that, I will probably go with a cover for the seat.
(2010 ISC 350)
Old 02-28-14, 06:41 AM
jgr7
jgr7's Avatar
Not sure where the mod thread is but all you do is put some kind of a deflector under the seat to aim the cool air from the under seat vent into the intake for the seat vent intake. Look under the seat and it will become clear to you what to do.
Old 02-28-14, 02:05 PM
txjeff
txjeff's Avatar
Oh, ok. Can you really get to all that under the seat without taking it out? (I haven't tried yet.)
Old 02-28-14, 02:25 PM
jgr7
jgr7's Avatar
Yes, I haven't done it but do remember the thread where it was done. The only thing that affected it if I remember correctly was changing the seat position.
Old 02-28-14, 03:38 PM
txjeff
txjeff's Avatar
Apparently, this is not an unusual problem
http://us.lexusownersclub.com/forums...no-difference/
I think I'm going to go another road. My Dodge Magnum had heated seats only but I never used them. Instead, I bought a cushion recommended by a trucker. I covered the cushion with thick seat vinyl that matched the leather seat. I never had a hot seat problem with it.
With the Lexus, I think I will go down a similar path, with thinner memory foam, since the seats are smaller, and use leather to match the seats. Then I won't even bother with the heat/cool feature.
Old 03-01-14, 12:19 AM
my1s250
my1s250's Avatar
if you have the a/c then it will be cool but if you just have the fan on then it will be just blowing air.
Old 03-01-14, 08:13 PM
txjeff
txjeff's Avatar
Hmmm.. That's interesting. Of course, if it's cooler out, I will have a bit of heat on, not AC. But the seat will get warm, regardless. So if it's AC dependent, I guess it's a part time usable system. I'll try that out and let you know if I see a significant difference.
In my opinion, if they just made the seats fully out of leather, they could ditch the whole heating/cooling crud. The seats would be comfortable.
Old 03-02-14, 04:42 PM
my1s250
my1s250's Avatar
if you turn on the a/c on high and the seat cooler on 3 then you will feel your bottom getting really cold.
Old 03-06-14, 06:39 AM
txjeff
txjeff's Avatar
Ok. thanks. Good to know. I'll give it a whack next week when I use the car again. (I have two and I'm using my other one this week.)
vu68
08-23-14 04:58 AM
IsdiorFlow
12-11-10 03:37 PM
Brian231
Chicago Lexus Club
10-09-08 09:42 AM
Integrator
01-21-03 12:35 AM
Quick Reply: Seat cooling mod
