IS C Discussion about the convertible IS C model
Replacing Low-Profile Tires?
Old 07-18-14, 12:36 PM
ALevinso
ALevinso's Avatar
Unhappy Replacing Low-Profile Tires?
Hey folks, I've got a question about replacing my tires. I've been a proud IS C owner for the last 4 months or so, and I'm loving my new car! That being said, I'm having one serious problem. That is I've had two bent rims and flat tires just in the last 4 months, presumably as a result of having the low-profile tires.
A bit about the wheels & tires:
I believe they're 19-in Alloy Wheels, though they came with the car, so I'm not totally sure. The front tires are listed as 225 / 35Z R19 88W
The car is a 2010 IS350c.
So my question is this, without replacing the wheels, is it possible to use tires that would be more likely to prevent rim damage? Anyone have experience with these rims/tires?
Thanks in advance!
Old 07-18-14, 03:01 PM
fknISC808
fknISC808's Avatar
Do you know what width your wheels are? if you dont know it, you could try a wider and taller tire. Maybe something like 235/40/19. what are your rear wheel specs?
Old 07-19-14, 09:16 AM
Gville350
Gville350's Avatar
Since it appears you are at a stock ride-height, you can probably get away with some 225/40/19s without rubbing. 235/40/19s would probably rub on hard cornering (taken from other members comments running that size) :
http://www.ebay.com/sch/Tires-/66471...5%2040%2019%20
Old 07-19-14, 09:19 AM
Snyperifle
Snyperifle's Avatar
If you have had two bent rims maybe it's time to get some different rims. Or drive slower/avoid potholes.
carrwash13
03-17-11 03:42 PM
CaliDogg54
12-25-09 04:50 PM
Helmar
10-22-09 08:34 AM
uaaction
05-23-09 01:04 PM
Scottina08
Wheels, Tires & Brakes Forum
01-06-08 01:44 PM
Quick Reply: Replacing Low-Profile Tires?
