IS C Discussion about the convertible IS C model
Open Door Indicator
Old 04-06-12, 08:05 PM
ATLSam
ATLSam's Avatar
Default Open Door Indicator
Since the past few days every time I turn (either way) in my '10 ISC the open door indicator for the left door goes of along with that annoying chime and that slight window opening/closing that occurs when a door is opened. Has anyone experienced this/found a fix? I really do not want to take a trip down to the dealership... its so dang far.
Every car I ever get seems to have bizarre problems...
Old 04-07-12, 12:28 AM
wslwang
wslwang's Avatar
Sound like you have a bad door push switch. It's a push switch with black rubber cover on it located aound stickers with tire pressure info. My old car had the similar problem when that swich is bend. You can try to push it and see if it working properly.
Old 04-07-12, 02:36 PM
fknISC808
fknISC808's Avatar
is it just me or does that chime come on whenever it feels like it? Some days, Ill turn the car off and open the door and nothing. Then some days, Ill open the door and goes off.
Old 04-08-12, 08:08 PM
mikes rx
I use "..." ....... a lot
mikes rx's Avatar
Yeah check the door switch plunger. One of the doors on my old IS sedan would occasionally stick in the closed position.
Make sure to check the screw that holds the plunger on the door is tight. I can't remember the exact details, but it's like a reverse ground or something.
Depends on when you open the door. If you open it when the car is still on (or I think in accessory mode as well), it will remain chiming until you shut the door. When that happens I usually just push the plunger with my finger.
Old 04-09-12, 08:12 AM
ATLSam
ATLSam's Avatar
Thanks! I tried that... it worked for a while, then it came back again :s
Old 04-09-12, 09:14 PM
fknISC808
fknISC808's Avatar
now that you mention that, it all makes sense. Thanks, I never put the two together. Thanks
Old 04-13-12, 05:27 PM
ATLSam
ATLSam's Avatar
Bizarrely enough... the problem came back. I took it to Lexus and they gave me a loaner car telling me they would call me about the problem.... Its been 2 days and no call yet.
Kiboater
RX - 4th Gen (2016-2022)
10-02-16 06:29 PM
Tsmith1982
03-29-15 02:36 PM
Dai Kaiju
SC- 1st Gen (1992-2000)
03-24-12 06:35 PM
Gville350
10-10-11 11:20 AM
Myeerah
Maintenance
01-08-06 07:36 PM
Quick Reply: Open Door Indicator
