IS C Discussion about the convertible IS C model
is IS convertible suspension compatible with sedan?
Old 12-06-11, 11:23 AM
viprtwo
viprtwo's Avatar
Default is IS convertible suspension compatible with sedan?
Hi,
My gut instinct tells me it should fit, but you never know. I searched "350c suspension" but didn't come up with anything. is IS convertible suspension compatible with the sedan?
Thanks!
Old 12-06-11, 09:02 PM
mikes rx
I use "..." ....... a lot
mikes rx's Avatar
With regard to the springs/shocks,
is it compatible???
.....I guess that answer is yes, according to the coilover vendors that I talked to, and what I've seen installed on verts.
However, is it "correct".....No, as the springs rates are different.
Just cause it's compatible doesn't mean it's correct. That's why Lexus has different part numbers for the springs/shocks.
So, my question, what are you trying to achieve????
Old 12-07-11, 09:29 PM
CircuitMS
CircuitMS's Avatar
All the bolt-up points are the same.
Old 12-08-11, 12:33 AM
viprtwo
viprtwo's Avatar
just wondering if an OEM sport suspension from a isx50C would be worth putting on a is350.
my other option is just to get coils. currently my oem shock/eibach spring combo kinda feels like it's on its last legs.
Old 04-06-12, 10:48 AM
jay90011
jay90011's Avatar
sorry for bring up such an old thread but i have a question in regards to only the Strut.
Are the Struts between the convertible and sedan the same ? I know the spring rates on the springs are different because the rear are stiffer but im wonder if the Front Struts are interchangeable.
I know the parts are different
Sedan is
4851080257 Front Right )
& convertible is 4851053210 (Front Right )
By the diagram for both sedan and convertible look identical. I placed an order for the convertible strut today and will try to see if they match with the sedan when i have received it.
Just wondering if anyone can confirm that they are interchangeable.
Thanks
Old 04-07-12, 02:33 PM
fknISC808
fknISC808's Avatar
Sedan is
Thanks
I think the fronts are but the rears are different. For example, a sedan air runner kit fits the vert but they needed to modify the rear strut and shorten it for the car to slam in the rear. just an example. let us know when you find out.
Old 04-07-12, 05:43 PM
jay90011
jay90011's Avatar
Thanks yeah I'm hopping the same thing that the fronts are the same . I will post up pics of it when I have paired them together. When they come in on Thursday .
Old 04-08-12, 07:46 PM
mikes rx
mikes rx's Avatar
Just because it "fits" doesn't mean it's correct. If lexus is showing different part numbers, I would use the one listed for your model. There's usually a reason for two part numbers.....otherwise the company would be able to carry less SKU's.
for suspension parts especially, I wouldn't go by "looks"
Old 04-09-12, 06:27 PM
jay90011
jay90011's Avatar
If anyone is interested the strut fit perfect with side by side pictures of the same dimension. I installed the strut and between the Oem sedan strut to the ISC strut the ride comparison is identical . The rebound is the same. I ran the part numbers at work (I work for Toyota financial) and was able to find the minimal dampner difference from the ISC to the sedan strut to be very minimal. Reason why I was unable to feel the difference. Again this is only for the FRONT strut on sedan Oem springs and hardware.
Reason why I bough the isC strut was due to not being able to find a used strut only for the IS sedan.
If anyone wants any details just send me a PM
The ISC strut part number used was 48510-53210
Old 04-10-12, 12:49 AM
fknISC808
fknISC808's Avatar
Thanks for the info, im sure it will come in handy one day.
Old 04-10-12, 07:04 AM
jay90011
jay90011's Avatar
Here is the pictures i took . hopefully it helps someone out .
aginnt
RC F (2015-present)
08-06-15 11:34 PM
nicholasg
03-09-09 01:25 PM
kevs98GS4
Suspension and Brakes
02-06-08 07:43 PM
lexem
01-05-07 09:48 AM
machinegt
01-27-04 12:50 AM
Quick Reply: is IS convertible suspension compatible with sedan?
