IS C Discussion about the convertible IS C model
IS250C lowering?
Old 02-10-10, 11:20 AM
ddotderek
ddotderek's Avatar
Default IS250C lowering?
Do the sedan is250 springs work on the is250c? Just wanted more options other then the 1 inch lexus fsport drop, thanks.
Old 02-10-10, 07:48 PM
mikes rx
I use "..." ....... a lot
mikes rx's Avatar
I wouldn't do it. According to the f-sport website, they use different size coils, drop it at different rates, and have different springs rates.
Combined with the fact that the vert also has specific f-sport shocks vs the other models, I'm thinking that anything but a kit designed specifically for the vert may be a bad idea.
If you're thinking springs now, I'd say just do the f-sports. If you're thinking about other options, I guess we gotta continue waiting to see what the aftermarket's going to come out with, if anything
Old 02-13-10, 03:00 PM
ddotderek
ddotderek's Avatar
Well coilovers will always work :/ I am shocked that no companies have came out with a set of springs...Im sure the f-sports keep the stock ride but the drop is a big weak. JaxISC has some fsports on 19s and although it looks good, it isn't low enough for my taste. Do you think if I got 20's & fsports that it would fill the gap a little more?
Old 02-13-10, 03:51 PM
mikes rx
mikes rx's Avatar
I personally wouldn't trust coilovers right now either for the same reasons I already mentioned.......unless you get custom spring rates, and even at that I still don't know if I'd want to be the guinea pig.
In terms of 20's and f-sports.....it'll probably make it worse cause the wheel will look big.
Old 02-14-10, 10:11 AM
IS-SV
IS-SV's Avatar
Yes I understand you want a lower drop on the IS-C than the F-Sports provide. Do you care about ride quality and handling or is that secondary?
Old 02-14-10, 10:12 AM
IS-SV
IS-SV's Avatar
Agreed because the short tire sidewall makes the wheelgap seem larger.
jlin7
11-19-16 06:42 AM
linus73
Suspension and Brakes
23
02-27-12 05:56 AM
mushybreak
08-20-10 09:29 AM
IS250_6Spd
12-03-08 08:17 AM
blk250
22
09-08-08 10:24 PM
Quick Reply: IS250C lowering?
