IS C Discussion about the convertible IS C model
IS350C vs. IS350 wheel offset question.
Old 01-20-10, 03:03 AM
ISCjonny
ISCjonny's Avatar
Default IS350C vs. IS350 wheel offset question.
anyone know if the wheel offsets on the IS350 and the IS350C are the same? or is the IS350C offsets different? maybe i should drop by the dealership and see if theyll let me do a test fitting. haha
Old 01-20-10, 04:29 AM
mikes rx
I use "..." ....... a lot
mikes rx's Avatar
YES, they use the same offset wheels from the factory.
MOREOVER....even though *visually* it looks like the C rear fenders don't stick out as much as the sedan, they in fact stick out SLIGHTLY more......
I did A LOT of research on this when I was playing with offsets for my wheels. I was very concerned that there wouldn't be as much space in the vert as there was in the sedan due to the way the rear fenders flare in the sedan vs the vert.
But, lo and behold, when I measured it vs a factory sedan, I found that there was about 1-2mm more room in the vert
Also, the vert has the same "issue" as the sedan where one side sticks out slightly more than the other (IIRC the left side sticks out more)
Here's a pic of mine for comparo. This is a 8.5" +40 front (225/35) and a 9" +40 rear (265/35). Factory ride height
Hope that helps. LMK if you have any other sedan vs vert questions. There's some parts that do interchange, and some that don't.....
And just some differences I've noticed from the 06 to the 10 model. https://www.clublexus.com/forums/is-...0-changes.html
lexus6838
05-28-17 03:04 PM
THE350
02-16-14 11:51 AM
djbugz
01-07-11 04:57 PM
Ken'sGS300
GS - 1st Gen (1993-1997)
12
09-07-07 02:46 PM
Quick Reply: IS350C vs. IS350 wheel offset question.
