LSD from RC350
Old 03-29-17, 11:54 AM
jkonquer
jkonquer's Avatar
Originally Posted by Solara350
traction control not enough for ya ? why you need LSD ?
Not sure if you are serious or joking?
Mike200T (03-29-17)
Old 03-29-17, 07:16 PM
Solara350
Solara350's Avatar
lol you're the only one noticed i was joking hahaha but hey you got a Thank from somebody
Old 07-28-17, 01:30 PM
Megaman
Megaman's Avatar
Any update on this?
Old 07-28-17, 08:03 PM
jkonquer
jkonquer's Avatar
It seems that it fits but just pricy $2000 to be exact
Old 07-28-17, 09:32 PM
LexSense
LexSense's Avatar
Ouch...
Well maybe once the RC's end up in more salvage yards we'd be able to grab these for a more reasonable price.
Old 07-28-17, 11:19 PM
jkonquer
jkonquer's Avatar
I call dibs, lol i wonder how many of rc owners actually opt'ed for a lsd. Im sure it is very low.
Old 07-30-17, 01:42 PM
Megaman
Megaman's Avatar
Do we have the correct part numbers for the LSD itself? I want to see what my employee discount would be on it through the dealership.
Old 07-30-17, 02:43 PM
jkonquer
jkonquer's Avatar
found it, its 41301-53051
http://www.jp-carparts.com/lexus/par...1&part=1099403
it seems they don't sell the lsd by itself, im sure there is a way to get that part alone.
i believe this is it
Old 08-02-17, 12:29 PM
E46CT
E46CT's Avatar
Received 2,064 Likes on 1,559 Posts
I'd get the diff for the sportier gear ratio alone (I am not sure if it is)
I wouldn't really be concerned about the LSD. These cars are too soft for that.
I imagine though the ratio is the same otherwise the RC350 w/ this option would need different EPA fuel economy #s as surely cruising speeds and acceleration would be different.. could be wrong though. Too lazy to hunt the ratios. can someone find it?
Old 08-02-17, 01:45 PM
jkonquer
jkonquer's Avatar
That would be ideal. Problem with lower gear ratio is that it messes up with the transmission logics on automatic vehicles. They had great success on 2IS manual but just not on 3IS, unless you have a tuner than knows how to program the logics. LexSense have done this his vehicle and he is having problems with the transmission shifting at random points.
Old 11-10-17, 03:13 PM
2013FSport
2013FSport's Avatar
Received 1,475 Likes on 1,230 Posts
My research came up with all the same #'s you folks did and I just won an RC350 housing complete with LSD for $300! Yippeeeeeee!
Only concern is words say RC350 RWD F-sport with LSD but the housing is finless like my 2IS.... hopefully it is the 24270 and all is well. Now to find a 4.08:1 donor gear and housing to reduce downtime....
Lucky day to look. PS housing took some abuse and has busted forward mount hence price...
Old 11-10-17, 03:15 PM
skiracer
skiracer's Avatar
Would the Torsen LSD on the 2018 IS 350 RWD work?
Old 11-10-17, 03:34 PM
2013FSport
2013FSport's Avatar
Do a where used for #41301-53051 Torsen LSD....
And I was just about to go big $$$ on clutch unit.
Old 11-10-17, 06:03 PM
jkonquer
jkonquer's Avatar
Keep us updated 2013FSport. Btw your car is a 3IS, correct?
Old 11-10-17, 06:18 PM
2013FSport
2013FSport's Avatar
Negative on that captain...
2IS.... Build and parts are the same tho except the the variance with the actual ratio... I'll leave link here but there will be a tear down and LSD carrier installed in a used 4.083:1 2IS housing. It seems timing is everything but once I get all the parts I'll document it. I've done like 30 gear setups and if I find a good used gear at least I don't have to set the pinion depth in a new case. Just preload and backlash on the LSD carrier swap.
I'll keep you guys...
LexSense (11-10-17)
Quick Reply: LSD from RC350
