RS*R Down question
RS*R Down question
I have RS*R Downs on my 3IS, but I don't like the way the front sits a little higher than the rear, does anyone know of a solution besides putting super downs on the front? Any help would be appreciated.
If you install Super Downs in the front then there's a slight chance that front will sit lower than the rear. I think it's better if you replace your current setup with Super Downs or go with another brand. Just check the specs to make sure the drop is higher than the Down springs. I currently have Half Down and regret not getting Down springs.
i have the downs and the front rake helps me clear speed bumps and steep driveways. downs are a really good option for being low and still being able to clear objects. the rake isn't there for looks, it provides functionality.
This is my car on super downs. i love the way it sits. some might thinks its too low but i think its perfect. the front end is slightly lower then the front. but for the most part pretty level.
& Hows ride quality?
Yeah everything else in this photo is stock. there is no rubbing at all. i scrap everyone once and whille on driveways n such. but thats to be expected when lowering a car.over all I like the springs alo, yeah Its a little more stiff then stock but nice enough to still daily. it handles turns a little better too.
RSR Coilovers... no gap, smooth ride.
FSPORT springs, advertised as 1 inch drop and plenty of gap and stiffer ride.
Not sure if it's ever in the budget, but if you can, I would replace the springs with Coilovers. I initially wanted to purchase the RSR super downs but was concerned about the added pressure put onto the stock shocks. Based on feedback on other threads and found on-line, I realize the ride would suffer for a specific look and the shocks would eventually go out so to the added force placed on the shocks. Imagine the suspension being placed under constant pressure without any relief? That's like placing 500 pounds or 4 adults in the car at all times? Results, quicker wear and eventual replacement required.
I eventually went to the RSR Coilovers and can't believe the smooth ride, better then stock and the adjustability. Check the pics and Shoot me a message if you have any questions. Good luck.
Originally Posted by Jmaarc13;9757572[img
https://cimg7.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/80-img_1716_16ce49daa4f142ddedc479b9d0d8e883539c3c1e.jpg[/img]RSR Coilovers... no gap, smooth ride.
Not at all. If you pull the manual of the car, you'll see the sport mode affects the gear ratio and the steering. Nothing changes with the Coilovers.
hope this helps.
hope this helps.
I don't think AWD even has AVS at all so wouldn't matter for me.
I've been wanting RSR Down's for the simplistic and cheap method of eliminating the wheel gap. Coils are expensive as I just bought the car. Can you guys post a couple photos of the way it sits and the rake pitch please?
