Mini or Low Profile Mini Fuses?
Does anyone know if the 3IS uses mini or low profile mini fuses?
Or does it use Lexus exclusive fuses?
peteharvey (01-26-17)
Thanks for that Answer.
I have to get a low profile mini fuse remover to remove the fuse, and then plug in a low profile mini fuse tap/piggy backs to the constant and switched power fuses to hardwire my dash cam.
Is it possible to use some of the empty sockets, then purchase two separate 5 Amp fuse, and wrap the yellow & red wires to the positive fuse end, and then plug those two fuses in - then we can close with the fuse cover?
Just depends if those empty sockets have constant or switched current.
From what I remember, there was not empty sockets that were satisfying the power needs, so those add-a-fuse are a must. And since they are bigger, the cover won't fit. Anyways, I just threw mine in the glove box!
LocoStrnge (04-09-23)
I was thinking of piggybacking the Hazard Warning Flasher fuse to get 12v constant, and the Radio fuse to get switched 12v.
Which fuses did you piggyback?
I'm thinking of using Haz & Radio.
Did you use the bolt in the second photo to ground/earth the negative black wire to your chassis, to return the current to the black negative terminal of the battery?
peteharvey (01-27-17)
Well, it looks like you have tapped into:
1) The Hazard Warning Flasher blue fuse @ 15A for your constant 12V power supply, and
2) The Ignition No 1 red fuse @ 10A for your accessories Acc ignition switched 12V power supply.
The two new fuses for your dash cam are 3 Amps each.
You have returned the current via the black wire, by earthing/grounding it to your hexagonal metal chassis screw at the bottom of the photo, as I originally suspected.
You have the exact same empty single and dual channel slots as me.
Thanks for sharing Answer...
