My 2015 IS250 F Sport came wired for Fog Lamps!!!
Today I was installing the OEM fog lamp kit from Nigel-JDMParts. I start with the installation of the lamps itself and then notice that there was a connector available on each side that plugs perfectly on the lamps, so I plugged them, then went inside of the car and before removing the steering wheel I start first removing the plastic garnish from the top and down of the steering column, for my surprise there was wiring on the pins 10 and 11 of the K23 conector, so I decided to try the new stalk immediately......... and then 😁😁😁😁 fog lamps start working perfectly, even the dash light for them works. 👍🏻👌🏻💪🏻
The K23 connector from my 2015 IS250 F Sport
Doing the test
Factory stalk pins
Fog lamp stalk pins
Factory stalk
Fog lamp stalk
Dash light
Picture on day light........... will be posting pictures of them at night
Doing the test
Factory stalk pins
Fog lamp stalk pins
Factory stalk
Fog lamp stalk
Dash light
Nigel-JDMParts (01-13-17)
Bertin3ISF (01-09-17)
Good job! I have to say though ,that this DIY looks beyond my abilities 😳. Seeing the steering wheel removed tells me that I will be calling my indie to do the install for me. Hopefully the harness is present in my '14 is350 also. Does anyone know definitively if it would be?
Nigel-JDMParts
10-13-13 02:55 PM
hawaiiboi
12-16-07 08:54 PM
